Letter 36039
How to do analysis of nickel bath
I want to test and measure the amount of nickel sulphate, nickel
chloride and boric acid amount in my nickel plating bath.
Bilman
- Turkey
Do you have a lab or any lab equipment? Are you a chemist or a lab
tech or any plating solution analysis experience?
Most chemical suppliers will be happy to give you a test procedure
for the chemical that they sell you. If you are buying proprietary
plating bath chemicals, that company will give you an analyses method
sheet and an operations sheet for the optimum level for each. Many
will even have a sales or tech services person show you how to do
it.
I imagine that you could even download it from the internet. There
are many many plating analyses books on the market, most using low
tech methods. High tech methods equipment would cost over $100,000
for state of the art equipment.
If you use the low tech methods, you will save a huge amount of
learning curve time and possibly avoid results that are "off" if you
have a qualified person show you how to do it.
Standard analytical procedures are available in most good
electroplating books. Try The
Canning Handbook.
R&D practical scientist - UK
