Letter 35084
Final Neutralization Rinse for Sulfuric Acid Anodize needed [Maryland]
A final acid neutralization rinse is needed for Mil-A-8625 [link is to info about spec at TechStreet], TYPE II, CLASS 2 coatings before our final Deionized Hot Water Rinse and parts Drying process steps. I thought about a hot/warm sodium, or potassium, bicarbonate hot soak @ 1 oz/gal, but no experience on use or possible side effects of introducing a neutralizing bath. Reason being that aluminum parts have braze welds with tiny pores and crevices that have trapped acid. Unfortunately, we cannot use chromic acid anodizing. Maybe someone has used and controlled a similar neutralization solution.
Tom Andersen
Anodizing - Balto., MD, USA
1st of two simultaneous responses--April +++++
I'm not sure what you want to neutralize. If you're worried about sulfuric acid, they you should use dilute (5%) nitric acid after double rinsing after anodize. I know this sounds counterintuitaive, but it works. Alkaline materials should be avoided since they will 1) precipitate metals. and 2) may damage the anodize coating.
- Spartanburg, SC, USA
2nd of two simultaneous responses-- +++++
Bicarbonate makes for a good controlled pH rinse as it is a buffer, so the pH tries to stay under 9.
That said, I doubt if you will get much neutralization of trapped acid in pores unless you add ultrasonics to it.
Also, Bicarbonate carry over into the seal or dye tank can significantly reduce the efficiency of that tank, which will require a lot more testing of those tanks.
- FL
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
