Letter 35010
Titanium Coloring [New York]
Need assistance in achieving Dark Grey to Black Color for 6AL4V
titanium using what ever "informal" process. I have heard of some
companies being able to achieve this through anodizing the piece, but
is there a thermal or less cost effective way to get a durable
finish?
David Harville
Hobbyist - NY, NY, US
You probably meant to say "more" rather than "less cost
effective", David. The most "informal" process is paint of some type,
but you haven't told us enough about the application to know if that
has any merit. "Durable finish" probably means both wear resistant
and corrosion resistant, right? But cost effectiveness almost always
depends on size and shape and volume to be processed. Is this one
single piece? How big is it? In short, what is the application? --
then we may be able to offer alternatives. Thanks.
finishing.com Inc. - Brick,
NJ
Just paint it with 2o% shellac solution(instead lacquer You can
use any edible oil or fat,use it very sparingly),then heat it up to
4oo C(slowly).Cheap,simple and durable finish.
- Zagreb, Croatia
Like Ted said...not enough info given.
As for anodizing...I dont think it is possible to get a black on
titanium. You can have titanium nitride coatings done but not actual
hobbyshop setup black anodizing. sometimes people will thermally
treat niobium (heat to about 1500 and dip in water) to get beautiful
hematite/black colors, or use aluminum and anodize with black
dye(which will fade from UV exposure over years)and use these 2
materials in place of titanium, in the jewelry industry for
example.
List more info and get more accurate help.
Jason Aube
- Flint, MI, USA
You can do black on titanium, but it is not common or
easy. I believe letter 30989
addresses it.
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
