-----How to Clean Brass and Protect from Tarnishing
Q. I just purchased several brass items online, and photos were of normal brass that I could clean, just looked dull in photos. However, I see that several of them have one side extremely shiny, gold in appearance. Looks like a golden finish was applied to one side of the horse figure at manufacture but not the other side. Anyone come across this and how can I remove it to clean as normal brass. Thanks for your time.
Arty Turner- Emsworth UK
December 15, 2020
A. Hi. A picture is worth a thousand words, Arty. I don't know whether you mean half of one surface is shiny and the other half is dull, or the front of something is shiny but the back is dull like on a door knocker, or what. Plus, sometimes surfaces are plated, sometimes not; sometimes they're lacquered, sometimes not.
You can consider whether there is a faded lacquer of clearcut, or whether the dull area was never polished, and some other ideas, but I think good clear photos (e-mailed to finishingdotcompublic@gmail.com) would help us understand your situation and be able to suggest a fix 🙂
December 2020
Q. I am installing solid brass light fixtures on the outside of my home. Is there some coating that I can put on to prevent tarnishing?
Dan Theno- Grove City, Ohio
A. Hello,
Your brass light fixtures probably already have a lacquer finish from the manufacturer. If you feel they don't, clean the brass with a lacquer thinner
[affil link] Flammable!
. If a bunch of gunk comes off, that would be the old lacquer. Keep stripping the lacquer off and polish the brass, then wipe off any polishing compound with the lacquer thinner
, get some decent exterior grade acrylic lacquer, spray, let dry and you are done. I'd wait at least a few months before doing any of this, it should be enough time to see if the brass was lacquered originally.
G. J. Nikolas &Co.,Inc.
Bellwood, Illinois
Q1. I have a medium size "Brass" collection that I clean often, my question is where or what can I use to protect my brass (keep it bright) after cleaning it? Any helpful suggestions?
Norma [surname deleted for privacy by Editor]- Logan, Utah, USA
Q2. Is it OK to spray lacquer on brass to keep it from tarnishing? If not, is there some other coating I could use for the same purpose?
- Oakland, California, USA
Q3. Pat,
I am also interested in knowing if I can use a lacquer on my old brass lanterns that are on either side of my front door. Can you tell me what you have found out about this.
- Charleston, South Carolina
A. Yes, folks, that's what brass lacquer is for. You can find out more about the technology of brass lacquers from G.J. Nikolas [a finishing.com supporting advertiser], and contact them for quantities of it.
For small quantities for home use, you can buy a spray can of brass lacquer. Good luck with it!
Refinish exterior brass light fixtures
Q. How do I refinish outside brass light fixture before painting the exterior of my house. It was pressure washed, which may have had bleach in the mixture. I have brass light fixtures, that got dull and one has dark places on it. Is there a way to bring back the shining brass and seal it?
Katherine Miller- Johnson City, Tennessee, USA
A. Hi Katherine. Brass lacquer will 'seal' it at least temporarily and is easily redone. But it's hard to say whether it's possible to get the stains out without a lot more info. Bleach attacks the zinc in brass but not the copper and it may not be possible to remove the stains short of polishing; and if it's plated brass rather than solid brass, the stains may be as deep as the plating.
Q. Saw your request for information about protecting the 'shine' on brass.
I have the same problem - I build clocks and keeping the look is a problem.
I would appreciate any information that works.
Many Thanks,
- La Canada Flintridge, California
A. Hi. Brass lacquer should have a long life indoors.
Q. My name is Jamie and my family has a chrome plating/powder coating company. What I would like to know is what would be the best way to protect brass indoors (such as church ware) -- type of lacquer or clear coat without leaving haze or overspray, or outdoors such as for lighting fixtures.
Jamie SzymanowskiPLATING AND POWDER COATING SHOP - Toledo, Ohio, USA
A. Jamie
There are alternatives available.
1) Indoors: Use a Nitrocellulose based material like Century lacquer from G.J. Nikolas [a finishing.com supporting advertiser]. It's the right way.
2) Outdoors: The brass will need Electrophoretic lacquering. This calls for in an Electrophoretic lacquering plant, and chemicals. E-Coat is the best direction to protect brass outdoors for say 3 to 4 years.
Asif Nurie [deceased]
- New Delhi, India
A. Indoors You can use any good nitrocellulose based lacquer, outdoors only 2-component epoxy or Incralac
