Letter 3477
Oil used for pressed parts is incompatible
with paint process. Help?
Dear Sir
My name is Murat Kirem and I am a Quality Engineer with an
automotive drivetrain company in Cheltenham Victoria Australia. We
manufacture value added pressed parts fro the Automotiv industry and
supply pressed parts for Holden, Toyota, Ford and PBR Brake systems.
We have recently and in the past have had numerous problems finding
an oil which is compatible with our EDP process of coating our
products. The oil we use for our pressings cannot be easily "washed
off" our parts and are consequently causing "snot" marks on our
products which is unacceptable to our customers. We do not EDP coat
our products ourselves and our supplier insists that it is the oil we
use and NOT his process of cleaning. Do you recommend a better oil,
one that may be synthetic, we are hearing stories from the US of oils
which can be used in Pressing operations and can be washed off with
hot water. Could you please advise
Murat Kirem
- Melbourne, Victoria, Australia
Murat - You bring up a couple of interesting points. The first, is
that your EDP coater says it isn't his cleaning process. This is
probably hogwash. He may need to investigate alternative cleaners
that will remove your hard-to-clean press oils. On the press oil
subject, yes there are some good synthetic press oils, but cleaning
them with just water is more fiction than fact. Go back to your
coater and offer to work with him in the search for better cleaning
chemistry - if that doesn't work, then start looking at less
tenacious pressworking fluids. Good Luck.
Dan Brewer
chemical process supplier - Gurnee, Illinois
