-----Prep of brass, silver, and copper before lacquering
After buffing with rouge and or brown tripoli buffing compound ⇦ on eBay or Amazon [affil link] , most small shops I have seen use lacquer thinner ⇦ on eBay or Amazon [affil link] Flammable! to hand wash parts before painting. Would like a safe solution.
Walter Poley- Jacksonville., Florida
Hi, Walter. I'm not sure what you are implying. That lacquer thinner
is a dangerous material? (Yes, it's somewhat flammable). Or that the operation is too labor intensive? Or that the workers are jeopardized by skin contact with lacquer thinner
The better way to clean brass and copper parts with lower labor, non-flammable solvents, and a much cleaner surface is via vapor degreasing. But this elegant solution has fallen into environmental disfavor due to the possibility of smog generation and/or chemicals that attack the ozone layer if the system is poorly managed. It's not an impossible situation though. Good luck!
February 19, 2009
