-----Patchy / stained Nickel chrome deposit
We do duplex nickel chrome plating of automobile wheel rims in an automatic plating plant using horizontal rack loading using both cylindrical central anode basket
⇦ huh? within the rack and external anode baskets. Anode baskets are titanium filled with nickel squares. The nickel plating is traditional Watts bath and the chrome is conventional Chromic acid/sulfuric acid.We have been facing a peculiar type of defect. This appears in the form of bluish white patchy/stained deposit. We have tried the following without much success :
1. Activating chrome dip before Chrome plating
2. Discard of Nickel Drag out more frequently
3. Improved rinse flow after nickel
4. Minimize transfer time from Semi-bright to Bright
5. Addition of Sodium lauryl sulphate to Bright Nickel
The brightener supplier has given us a proprietary salt which he calls Nickel Sequestrant. Addition of this gives relief albeit temporarily. The problem reappears after a couple of days. Can someone suggest what I need to do ?
an electronics company - Bangalore, India
You really didn't specify whether you saw this in the Nickel or only after Chrome plating. If the Nickel looks fine then a close look at the Chrome is necessary. Temperature imbalances can cause this.
There is also a common problem called whitewash. This usually occurs with older solutions with high levels of metallic contamination. These trace metals seem to plate out in the lower current densities causing a haze. My troubleshooting rule of thumb has always been to work my way back from the process where the defects first become obvious.
Jim Conner
Mabank, Texas USA
