-----Need an immersion solvent parts washer
We are looking for a solvent parts washer, immersion type at room temperature. The petroleum solvent P-D-680 type 2 will be used. Agitation of the parts in the tank is needed. The approximate inside dimentions of the tank are 50 cm by 50 cm by 60 cm deep. The cleaning tank shall have permanent filtration.
Alex Sirotacleaning shop - Lod, Israel
