Removal of copper oxide using cyanide
My question relates to the removal of copper oxide from sterling silver parts using a mixture of sodium cyanide, water, and hydrogen peroxide. Sterling silver parts (92.5% silver and 7.5% copper) are soldered using a traditional soldering operation. A copper oxide forms on the parts. The copper oxide is removed using a three bath process.
The first bath contains a mixture of:
100 mL dilute sodium cyanide (180 g/L NaCN)
1.5 L H20
100 mL hydrogen peroxide
The second bath contains:
400 mL of dilute sodium cyanide (180 g/L NaCN)
3L H20
The third bath contains only water.
Questions:
Any information/suggestions much appreciated.
kelley begin
- boston, Massachusetts
It appears that you have oxidation-reduction reaction. Hydrogen peroxide is a mild oxidizing agent. So NaCN will be oxidized to NaOH or Na2CO3 and copper oxide is reduced to copper, removing oxide. As an alternative you my try 10% acetic acid on eBay or Amazon [affil link] solution, preferably hot for a duration that will depend on oxide thickness.
Ram Singh
Sunnyvale, California
