Letter 3309
Black Optical Coatings on 316L Stainless
Steel
I have an application where we need to decrease the parasitic
optical reflections on a 316L stainless steel part. The used light is
around 890 nm wavelength.
What kind of black optical coatings are available?
Do you have any ideas on where I can look for this information?
Thank you for your help.
Pere Llosas
- Switzerland
I have seen black chromated alkaline zinc used over brass laser
timing gears for an optical timing device which had similar optical
requirements. In this case prior to black zinc, a woods nickel would
be required in order to zinc plate the stainless. The black chromate
had to be baby sat during the chromating operation due to the high QA
requirements.
Ward Barcafer, CEF aerospace - Wichita, Kansas
Try a room temp black oxide coating. Although this is not a true
black oxide, it should provide a reasonably dulled almost matte
finish.
Dan Brewer
chemical process supplier - Gurnee, Illinois
August 27, 2009
We use a process that produces a nice black iron oxide coat with a
matte finish. We vacuum bake the parts to use in our UHV vessel.
Usually there is some loose amount oxide that we wipe off/lightly
sonicate. The specification for the process is:
mil-13924
For a matte finish that it is vacuum compatible you MUST also
specify:
NO OIL, NO WAX, NO SEAL
NO TESTING
Alan Bobalan
- Irvine, CA, USA
