Letter 3304
- "Our customer has requested that we Zinc plate with Yellow Chromate, Vinyl wash primer, yellow Zinc Chromate primer, wet coat baking enamel. On small test samples we appears to achieve proper bondage. However, on actual racks, we loose bondage around bolt holes and pressure points." STOP! At this point, you need to see if this coating system is reasonable. Ask to see the military specification or some other basis for this coating system. It can't be a list of mil specs for each individual coating, it must be for the system. Your vendors of coatings can help, but you have to work from the top coat backwards to the primer, then wash, then chromate. Unless you formulate your own paint, you can get a recommendation for compatible bottom coats. |
Tom Pullizzi |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
