-----Polishing a Huffer
I was wondering if you could tell me what to use for polishing my blower (supercharger)which has a satin finish.If you could give me some advice or send me some information it would be appreciated, THANKS!
Tyson Gerry- Cottage Grove, Minnesota
Purchase 3 Black & Decker buffing wheels, about 6" diameter, from your local hardware store. Attach the wheels on a shaft attached to an electric motor (no more than 1800 rpm); use red jeweler's rouge ⇦ on eBay or Amazon [affil link] as your polishing compound, (also known as brown tripoli buffing compound ⇦ on eBay or Amazon [affil link] ); start polishing. However, if the blower is anodized, then you will have to contact a metal plating or polishing shop. Good Luck!
Gary Patigler- Richmond, California
It sounds like you have a Satin Finish. Try and Non-woven hand pad (Scotchbrite) or greaseless buffing compound. If it's a mirror finish I would try a bar compound. Green rouge or white coloring bar.
Ron Penque- Barnegat New Jersey
I would like to strip the paint off of my motorcycle rims and polish the rims out. Can I do this myself or will I have to contact a polishing shop.
If I can do this job what will I need and what is the proper procedure.
- Jackson, Tennessee
