Sharpening stump grinder teeth
     Some very good info on sharpening stump grinder teeth is on this page. But unfortunately ...
     We know that some "satisfied customers" and "dis-satisfied customers" were actually hawkers posting with fictitious names to praise their own product or criticize their competitor -- but we don't know which posters have vested interests and which don't  🙂 Read on, join in, but to the extent practical please try to avoid testimonials ...
Q. Hi
I am a Stump grinder using small Tungsten Carbide tips and looking at using this type of technique or purchasing a small machine that I can use to sharpen my own teeth
John Cairns
- Brisbane, Australia
A. Hello John,
I've been removing Trees and stumps for over 20 years. I have yet to find a better way to sharpen carbide teeth than how I've been doing it. The simple way is to use a grinder with two different wheels on it, at two slightly different angles on the front resting plate. Use the first wheel made of carborundum to grind the shank of the tooth away from the bit at a 120 degree angle until the area being ground comes in contact with the carbide, then stop. Don't overheat it, keep dipping it into water. Then use an Industrial Green (diamond impregnated) wheel at a 95 degree angle to the bit so the shank stays clear of the stump and all that will touch the wood will be the bit. You may have to repeat this several times to accomplish a good sharp tool. Try not to let the green wheel come in contact with the shank of the tooth. The soft metal eats it up. And as they can cost a considerable amount of money, it pays to be as careful as you can. However, I find that by doing it the way I have just explained, if I replace the teeth before they get too worn, I can sharpen them as many as 3 times before they're no good any more. This method has saved me a small fortune over the years and still is.
Although this can take some time to sharpen a full set of teeth, I try to keep enough ready to change at least the pairs that protrude from the cutting wheel the furthest at least twice a day. Then I use bad weather days as a time to sharpen more. Remember to wear safety glasses and even more important a GOOD filter for breathing as the dust from this operation is lethal ...
Good luck, hope I was of help,
Terry Kuntz
stump removal - Shallotte, North Carolina
Ed. note: Thanks Terry. Readers should wear those good filters when doing ANY process which creates dust . There is no such thing as dust which is harmless to inhale.  🙂
A. I have been grinding stumps since 1976 have looked around for YEARS for a hand-held tooth dressing device - I use a bench grinder with a green wheel and a normal metal wheel -- rest it on my knees and sit on a stool behind the machine and dress the teeth in place- obviously not the safest way to do it but I have never been injured and it saves about an hour vs. removing all the teeth. The grinding wheel for the carbide is often called a green wheel. If someone knows of a hand-held sharpening device that will dress the carbide ends of the teeth please let me know.
Michael Simmons
stump grinding - Woodinville, Washington
A. [company name deleted by editor -- apologies, see Ed. note] makes a machine just for sharpening stump Grinder teeth. It has a special form diamond wheel for grinding the bit and the carbide to the original shape. It is a little expensive but it will sharpen thousands of teeth with only occasional washing to clean the sap, etc., that builds up in the wheel. You do have to take the teeth out of the stump grinder to sharpen them.
Ken Frea
- Sturgeon Bay, Wisconsin
Ed. note: Predictably, as soon as commercial interests are involved, trouble starts! Another reader (possibly even a competitor posing as a dissatisfied user) publicly trashed this product and the company that Ken suggested. We can't post public trashing, which then makes it unbalanced to leave a recommendation on line either, so we had to remove the company name. Sorry. No testimonials please!
We welcome advice on techniques & practices, but we don't like to post recommendations of particular products or sources. If a seller feels they have a commercial solution, they are welcome to advertise anywhere, including here. Apologies.
Q. I have a tree service and stump grinding business and I am having a heck of a time trying to find carbide teeth on a stump grinder called "hydraulic stump buster" model sc-25 made by, Shavers Manufacturing co. I can get them through Shavers but , they are $25.50 per tooth. I find it hard to believe that they can be this much, so if anyone has information on how to get these cheaper please let me know, thanks.
Kevin Jasa
- Estherville, Iowa, USA
A. Try border city tool, can be found and ordered online. I just ordered a set of standard rayco teeth. $ 2.47 EA.
Staven Stumper
Mike's Stump Grinding - New Haven, Connecticut, USA
Q. I HAVE TWO VERMEER SC252 STUMP GRINDERS. MY QUESTION IS MY DEALER HAS QUIT SELLING CARBIDE TIPS FOR THE TEETH. IN THE PAST I HAVE BEEN ABLE TO BUY THESE TIPS AND SILVER SOLDER NEW TIPS ON OLD TEETH. DO YOU KNOW WHERE I CAN BUY NEW TIPS. THANK YOU.
BILL MURPHY
STUMP GRINDING - YUKON, OKLAHOMA
Q. I just bought a used stump grinder (made in Lowell, Indiana by someone named Fox) and I need some new carbide tipped teeth (or at least some carbide nibs, and I'll have them brazed on). Anyone know this outfit or can give me a lead.
Mark Burns
farm - Vashon, Washington
Q. [Company name deleted by editor -- apologies] sells a die grinder wheel to sharpen teeth.
Does anyone know someone near the Lansing MI area that can retip carbide teeth? I'm using super teeth .
Ray
Raymond Raska
Stump Grinding - Ovid, Michigan
Ed. note: Apologies, readers, but because we had to remove the recommendation for another brand of die grinder as we previously mentioned, now it's not fair to publicly recommend just their competitor :-( Please try your best to offer techniques and methods but not commercial suggestions. This nonsense is, unfortunately, just what happens when money becomes involved. Thanks!
A. If you can't find teeth consider converting to Green Teeth
Carl Brewer
- Naples, Florida
A. We sharpen all kinds of stump grinding teeth, For the last 10 yrs. THANKS! RAY
Ray Johnson
tool grinding service - Sylvester, Georgia
A. Hi
I am doing stump grinding in Norway. I have rocky soils and clay. When I only used a 25 hp machine I used to sharpen the teeth. Now I have a big machine with super teeth and I find I have to grind the teeth dull before putting them on, If not the carbide tip will be thrown off immediately. Bought my first Rayco RG 50 five years ago.
Lars Honningsvaag
stump grinding - Oslo, Norway
A. I repair and replace my own carbide teeth.
Praxis Illinois Inc. in DeKalb, IL sells stump grinder carbide teeth and silver solder.
Bob Hooser
- St.Charles, Illinois
A. I have been using Greenteeth since they came out on the market and they are great and I resharpen them myself. They prove to be very cost effective and long lasting.
Larry Jolliff
- Yukon, Oklahoma
March 2, 2008
Q. I recently took a lot of damage to my stump grinder vermeer pocket teeth (not the half inchers, the ones with the dimple in the part that goes into the pocket) I'm changing from the pocket type teeth, and either going to super teeth or green teeth. I'm tired of them breaking off before they are dull. Anyone have experience with BOTH? I have super teeth on my other stump grinder, and am pretty happy with them, but I hear about the green teeth being good. The green tooth lovers speak highly, but I would appreciate some feedback from someone who has used them both.
Chip Lowell
tree service owner - Walla Walla, Washington, USA
June 26, 2008
A. To sharpen teeth I don't take them off my wheel. I use a hand drill with an arbor that holds a green wheel (about 6-8 inches dia.) I can sharpen right on the wheel. Like any cutting edge, I sharpen at an angle, taking the round out, and making sure that the cutting edge protrudes. It works fine, and I can go around my small stump grinder in about an hour, longer on the big stump grinder. I save all the time of removing the teeth, since we all have had the fight of removal/breakage/stripping of the bolts. The wheels have cost me, in the past, about 30 bucks each. they DO get used up on the soft metal part, but I can get a lot of sharpening out of them before the wheel is used up.
Chip Lowell
tree service - Walla Walla, Washington
June 26, 2008
Q. Stump grinder frustration! I have a Shaver Model sc-25 3-point stumpbuster. Recently I ordered new teeth from the company and they sent me 2 1/4 inch teeth but the original teeth are 2 7/8 inch teeth. The company told me they don't make that size teeth anymore. I would like to find a place that makes the 2 7/8 inch teeth. Can anyone help me?
Jerry Benbrook
stump grinding - Blue Mound, Kansas
July 9, 2008
A. You can find a company selling three different lengths for the shaver including 2 7/8" on eBay .
Steve Isabelle
- Murphy, North Carolina
October 27, 2008
A. If you're having problems re-sharpening stump grinding teeth take a look at this website: www.chipperblades.co.uk
Simon Jackson
- Sheffield, S Yorkshire, England
December 11, 2008
A. I found a place that sells the carbide tips, solder and the flux, it is on the web it's stumpgrinderteeth.com.
Vincent Harding
- Denver, Colorado
January 26, 2009
A. www.sharptool.com for stump cutters.
P. Morette
- Hudson Massachusetts
April 17, 2009
A. To Raymond in Michigan looking for someone to retip your super teeth. I've used Discount Stump Cutters out of Lincoln, MI for the past 10 years.
Rex Danely
stump eaters - Logansport, Indiana
April 30, 2009
A. Syntech Abrasives in Charlotte NC that makes diamond grinding wheels for sharpening the stump grinding teeth.
TOMMY DAVIS
- CHARLOTTE, North Carolina, USA
June 3, 2009
Ed. note-- Readers: If you wish to "softly" name additional companies, it's probably okay. But please omit testimonials and "I am not affiliated with" :-)
A testimonial from a stranger is worthless anyway, but in this case it quickly led to a race to the bottom where each vendor posted ever more extravagant prose about their brand. In one case they posted with an "I am not affiliated with", then a fictitious name and town, posing as a satisfied customer -- but their IP address was the same as the vendor's website :-)
We've wasted a huge amount of time revising and deleting long-winded advertising copy from this page, knocks of other brands, etc. Thanks for your understanding!
A. Look up New River Equipment and order you a wheel from them. Your teeth will only cost you 9.00 each. I use a 4012 with Sanvik 2007 model. I have to pay 13.00 each.
David Moody
moody tree service and stump grinding - Elkmont Alabama
August 23, 2011
Q. I just purchased a stump grinder (Praxis) and plan on sharpening the blades myself. There are numerous grits to the 2 needed wheels (aluminum oxide, and green silicone carbide) and need to know what grit to purchase in each. Thank you.
Macey Glinka
- Pasadena, Maryland
August 20, 2013
A. I sharpen all types of stump grinder teeth fast. I use a surface grinder; it's very fast --
www.moodytreeservice.com
david moody
- deatsville Alabama
July 25, 2014
Ed. update: No such URL anymore.
