Letter 3104
Zinc nickel
European motor manufacturers are insisting that many vehicle
components be zinc nickled and not acid or cyanide zinc plated. Can
anyone please advise on an easy and cheaper way of converting an
existing acid zinc plant, both barrel and rack plating, to a zinc
nickel plant without having to dump and start over again. Is there a
way of converting the solution over a period of time. Apparently
there are 2 ways of doing zinc nickel plating. Which way in the best?
We are in need of detailed technical assistance.
John Mattisson
plating - South Africa
Dear Mr Mattison ,
Yes indeed there are two forms of Zinc - Nickel plating , one acid
the other alkaline , and yes conventional acid Zinc can be converted
to Acid Zinc - Nickel . the procedure is relatively simple , and
control of the Nickel level is relatively simple . Have you not
spoken to your local "Suppliers" about this ? Best regards
John Tenison - Woods
- Victoria Australia
Dear Mr. Mattison:
I have not been to happy with any of the acidic zinc/nickel
formulations that I have encountered, except for reel to reel strip
line plating. The constant current density takes advantage of the
fact that you will see higher nickel in the low current areas of
complicated parts.
The alkaline baths on the market are not convertible from other
processes. Cyanide Zinc can NEVER be used, as it forms Nickel
Tetracyanide complex. As little as 30 PPM will totally destroy a
bath.
There are several vendors selling zinc/nickel technology today. Be
sure that the European firm tells you whether they want a low
percenter or a high percenter for nickel codeposition. The low plates
at 5 - 9%Nickel; the High at 10 - 15% Nickel. In Europe, some
automakers specify a bake at 120 deg.C. for 24 hours to the
passivated zinc/Nickel prior to entry into Salt Spray testing. Then
they want 240 hrs to white corrosion. A difficult feat for the low
percenter.
Ed Budman
- Pennsylvania
