Letter 3061
Plating on Magnesium
I have had some inquiries for plating on magnesium. Can anyone suggest some good sources for processing and some of the "Watchouts" attached to the process. My in house library doesn"t have much. Any help is welcome. Chris
Chris Hammer
- WNY, NJ
Don't forget that chips and shavings are flammable if you are doing any mechanical work on the parts. Magnesium parts must either be zincated or nickel plated, and in either case the zincating or nickel plating must be preceded by rather detailed pickling sequences. Volume 5: Surface Engineering of the ASM Metals Handbook has a great chapter on Magnesium Finishing--at least my ninth edition does, and its available used and cheap from this link at Abebooks)
Ted Mooney
finishing.com - Brick, NJ
Aug 1,1999
I have seen work done by a company in New Zealand [Auckland Aluminium Limited, Auckland] that is a form of anodising magnesium - very interesting..
Hamish Hawthorn
- Australia
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
