Dear Sir/ma'am,
I have a roller skate plate and truck assembly that I
need gold plated. The plate is made of aluminum, and the
truck assembly is made of steel. The associated mounting
hardware (screws, bolts and nuts) are aluminum (I guess).
Here is the problem. The truck assembly is riveted to the
the roller skate plate. And I have heard that plating the
two metals, while mounted together is not possible. My
problem is this - I do not have the rivets that are used to
keep the two pieces together, nor do I have a source for
obtaining them.
The goal is to get the entire assembly, mounting hardware
included - gold plated. I have had it done on my existing
skates about 5 years ago, but the company that I had do it,
is no longer in business and all I did was basically drop
off my skates (boots attached) and 3 weeks later, they were
done, all parts gold plated, no questions asked. The
questions I need answered are as follows: Can the parts be
plated while mounted together?
Jaye F [last name deleted for privacy due to age of
posting]
Rollerskating - Poquoson, Virginia, USA
