-----pH control in the SnPb and pure tin bath
Hi!
I am a plating engr and would like to understand further the effect of high or low pH in the electroplating bath for SnPb and Pure Tin process.
Beatriz C. AmioPlating shop - Muntinlupa, Manila, Philippines
If the base of your bath is fluoborate, you should only control the concentration of fluoboric acid and pH control isn't necessary.
Mahdi Farahani
engine parts - Qazvin, Iran
