-----Aluminum etching
Dear Sirs & Madam,
I am studying the cleanliness of aluminum metal and want to remove aluminum metal from the matrix and keep the inclusions on the surface of the sample. The treated sample will be investigated using scanning electron microscope (SEM). The photos taken during SEM study will be quantitatively analyzed using image analysis. Could you kindly advice me what is the best way to remove part of matrix and keep the inclusions?
Thank you for the help,
materials science - Toronto, Ontario, Canada
Hello,
I would like to know what is the etching/keller solution use to determine the microstructure of Aluminum 6061.
I'm study the notch shape tensile fracture of aluminum. U-shape & V-shape.
Thank You
- Malaysia
