-----CUTTING TOOL LIFE IMPROVEMENT
I am thinking of going for Cryogenic Treatment for our HSS cutting Tools, such as Drills & Reamers. Please let me know the life increase value with this process. If any new technology has evolved, please let me know.
ADAVALLI HARIAUTOMOBILES - MUMBAI, MAHARASHTRA, INDIA
Cryogenic treatment of HSS cutting tools for increased wear resistance is an ideal application. One of the benefits is that the it is a "through metal" treatment -- not a surface coating or surface modification. So if you are able to resharpen the tools, the benefits will continue to be in effect after the re-sharp. Generally speaking, the cost is significantly below a coating also. It is not unusual to see an increase of 150% to 300% of the "pre-treatment" life. Some people report even greater results, but I feel that a doubling of life is a reasonable expectation. Be sure to use a "deep cryogenic treatment" to -300 °F - very gradually applied with an extended dwell (e.g. 24 hours). Also, be sure there is a post temper or heating cycle.
Robin RhodesWorcester, Massachusetts
