Letter 29083
Information on hard chrome plating
We have a T shaped small component called a Choke Block. This
block rotates in a steel fork bore & works in an abrasive
environment like dust, carbon soot, and dampness. Presently it is
carburised & hardened. However I want it Chrome plated to improve
wear resistance & prevent rusting/corrosion. My questions pertain
to this situation & need the clarification on the same.
What is the threshold thickness value for hard chrome plating
& decorative chrome plating ? Does component needs to be hardened
before hard chrome plating ? What is the advantage of hardening a
component before hard chrome plating ? Does hard chrome layer of
15micron work well in abrasive condition? What is mean by chrome
flash ? What test is used to detect Hydrogen Embrittlement?
Rajesh Talathi
Quality Engineer - Pune, Maharashtra, India
Dear Mr. Talathi,
I hope someone else will answer your questions. I can only give
you some informations about our use of chrome (we use chrome in
abrasive enviromental too: chrome vs melt glass). The thickness value
for hard chrome is usually 6-8 micron but we can work without
problems with 15 micron too. I know that an hardening of components
before hard chrome planting can give a bad adherence of chrome.
Finally I've got a question for you: Do you think that Hydrogen,
inglobed in hard chrome, is able to influence layer's hardness or
wear resistance?
Best regards,
Luca Tosini
- Fidenza, Parma, Italy
Mr. Tosini,
Lab research has demonstrated that not only Hydrogen but also
Oxygen dissolved in the chrome layer have the highest influence on
hardness. Vaccum treated Chrome to eliminate theese "impurities" has
a hardness of only 400-500HV instead of 1000-1100HV.
Guillermo Marrufo
Monterrey, NL, Mexico
Thank you Mr. Marrufo
Do you think that a simple thermal treatment at 500-550°C
coulds help me to increase wear resistance? (at about 500-550°C
Hydrogen leaves Chrome that passes from hexnagonal to cubuc
structure)
Best regards
Tosini Luca
First of two simultaneous responses -- ++++
Generally, chrome with hardness above 1,000Kg/mm2 is BCC, whereas
hexagonal structure is found in softer plates. Your proposed heat
treatment of chrome above 400oC will eliminate Hydrogen but very
little Oxygen. With this treatment hardness may drop up to 30% due to
recrystallization, stress relieve and grain growth. Now, it is
important to say that hardness is not a linear function to wear
resistance.
Guillermo Marrufo
Second of two simultaneous responses -- ++++
Why are you baking the part at such a high temp? "Normal" bake
temp is 375 to 450F, not C. Why do you think that you have a hydrogen
embrittlement problem? You can prevent most of any hydrogen
embrittlement by simply not etching or pickeling it as long. Also,
you can avoid sharp corners by employing generous radius on all
corners. You can also shot peen before plate. You can also prebake.
You can extend the length of the bake. You can get it into the bake
oven quicker after it comes out of the final rinse.Far too many
people have heard of hydrogen embrittlement, so blame every failure
on it. It is not Cyanide or Cancer, but far too many people are
finding goblins under their bed at night when there are none. In
short, make sure that you have a problem berore you waste time, money
and energy trying to fix it. PS , notch bar testing is the common way
to check for a problem. Destructive loading of a part is wonderful if
it physically lends itself to the testing.
Mr Talathi,
I suggest the following sequence:
1) Clean in an alk soak cleaner at 70 C for 4-6 minutes.
2) Anodic clean at 75 c for 2 Minutes
3) Rinse well twice
4) Check if Rust is present . Anodic de rust in a derusting solution.
This is alkaline and runs 75 centigrade anodically and is available
domestically.
5) rinse twice plain city water
6) neutralise in 5 % dilute sulfuric for 30 secs.
7) Plate Sulfur Free Semi Bright Nickel.. 6 to 10 Microns Dragout +
two rinses. ( NOT BRIGHT NICKEL PLS NOTE)
8) Dilute Chromic dip or dip in Chrome dragout.
9) plate Chrome as usual to regular thickness.
10) dragout and two rinses
11) Hot Deionised water rinse at 90 centigrade for 1 Min immersion.
Air dry and replace the DI water daily. The Hydrogen Embrittlement
will be present for academic purposes in the part. The Nickel will
eliminate corossion failure.
est for performance.. Good Luck
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
