-----Electropolishing titanium. Formula and method.
We are looking for a machine to electropolish small titanium medical components about 12 mm OD 26 mm long with a 3 mm Hole through the center. Can anyone tell me where we can get information on this process or who can supply such equipment.
medical components - Shannon, Co. Clare, Ireland
A. Hello Billy.
The metal finishing industry is highly regulated environmentally; in fact it was the nation's first categorically regulated industry. This means that you need to apply for discharge permits, keep track of waste accumulation dates, etc. For this reason and others, the metal finishing industry is extremely jobshop oriented, and most manufacturers subcontract their electropolishing needs. This is not to say that you can't install an electropolishing system -- only that there is an alternative you may not have considered yet.
Generally, an electropolishing system is not called a machine because it is not a packaged entity but a bunch of tanks, a separate ventilation system, maybe a transport mechanism, a wastewater treatment system, and various heating, cooling, air agitation
⇦ huh?
, and purification accessories. I am not challenging your grammar, just trying to help by conveying the idea that the operation is more process oriented than machine oriented. It's rather like the idea that a brewery doesn't make beer by buying a beer brewing machine. The general electropolishing process is explained in several plating textbooks including the
Electroplating Engineering Handbook ⇦ this on
eBay,
AbeBooks, or
, the Metal Finishing Guidebook, and
ASM's Metals Handbook Vol. 5.
A. Electropolish requires excellent connections to avoid arcing damage to the part. Your part is small, so would require a fair amount of rack setup time. Are you locked into electropolish to the point that a mass finishing system would not suffice? There is at least one vendor at this site that specializes in electropolish and may have something for titanium. Note that it is a tiny fraction of SS that is electropolished, so may not have a lot of vendors in that branch of the field.
James Watts- Navarre, Florida
A. Billy,
Russamer Lab manufactures such equipment for titanium electropolishing and sell this process and equipment to the shops. The process is environmentally safe since titanium is electropolished in salts, not acid. It takes about few minutes to polish titanium medical parts by our high-voltage equipment. This process is good for small parts since a lot of power is required.
However we are experimenting with low-voltage titanium polishing, which is good for big parts (also environmentally safe). Some of the titanium alloy are polished quite well. We have discovered this method accidentally while testing environmentally safe method of polishing large nickel surfaces. Anyway, in order to suggest one or another method, we need to test samples and hear all the requirements.
Anna Berkovich
Environmentally safe-- Semantics! The acids used in other electropolishing can be neutralized by "elementary neutralization" with little or no grief from the environmental folks. To my failing memory, Ti and vanadium are not regulated wastes. The aluminum in 6-4 is, after it reaches a level of around 30 ppm. The real killer to electropolishing waste is the copper from the racks. This puts it squarely into a regulated waste. Anna's "salts" may not start out as regulated (as acids are, but they will end up being regulated when they have enough aluminum or copper or any other regulated metal. Other than the high voltage, it sounds like their process is a lot more operator friendly and highly probable of less air quality problems than the warm acid bath with lots of outgassing.
Formula for titanium electropolishing
Q. RE: Titanium I'm interested in a generic formulation for electropolishing or bright dipping of Titanium.
Louis HirbourChemical supplier - Anaheim , California, USA
A. Chemical polishing of titanium:
60-62% Perhydrol(Hydrogen peroxide)
8-10% Hydrofluoric acid
30-31% water
temp. 20 °C, 30-60 min.
A. The method you suggest is damaging for the environment and workers.
There is a proprietary method of polishing titanium in saline-based solution. Contact us if interested.
Anna Berkovich
Electropolishing Titanium to make it reflective?
I am interested in making an inner tube made from Titanium more reflective. I thought about electropolish but I don't know if it is possible.
Please advise if it is possible or if there are anything else I can do.
Product designer - Israel
A. Yes, titanium can be polished very well and without hazardous problems.
We have already implemented this technology in Italy, two titanium processing shops in United States coming this fall.
See picture attached.
Anna Berkovich
Q. Hello all,
I am currently in the process of determining the best parameters to electropolish some Ti-6Al-4V. Most electrolyte solutions I have found in research lead me to using perchloric acid, something my company does not allow on the premises. So, we went with an alcohol based solution. here is the recipe:
700 ml/L Ethanol 100%
300 ml/L Isopropyl Alcohol 99%
60 g Aluminum Chloride
250 g Zinc Chloride
30 °C
75V
At the moment, I am struggling to get the current density up, and this is causing more etching and passivation than anything.
Any suggestions on how to up the current density so I can get into the polishing zone?
- Lansing, Michigan, USA
A. Hi Calvin. One thing I can tell you is that your company is right in eschewing perchloric acid ... which was responsible for the worst metal finishing accident in U.S. history (see letter 9408). Good luck.
November 2015
