Need test kit to find lead paint
Q. I need portable cheap lead detectors for paint
cort stull
- mcalester ok
Lead Test Swabs
lead_test_swabs
A. There is a product called "Lead Check Swabs" made by BGI Incorporated. You should be able to find them with a search. I talked to them on the phone and they seemed very knowledgable and helpful. There are also lead testing crayons commercially available, though I have heard they're prone to give false positive readings.
dave wichern
Dave Wichern
A. It depends on what you mean by "cheap", and who the analysis results are for. If you need results that are going to be in any way required or reviewed by regulatory agencies for compliance, or if your customers are going to be held to account in the same way, Atomic Absorption Spectroscopy on eBay or Amazon [affil link] is the cheapest, by far.
rachel cassai
- olympia, Washington
