How to Patina Copper
"The Colouring, Bronzing & Patination of Metals"
by Hughes & Rowe
coloring_bronzing
Modern Masters Green Patina
modernmasters_green
I would like to know the fastest way to age copper without using chemicals. And if I have to use chemicals what is the best product to create patina on copper and where can I get it in the New Orleans, Metairie, LA area? Thanks, Tara
Tara Rabalais
- Chalmette, Louisiana
Hi, Tara. "Patina on copper" is the topic of dozens of letters here, so can search the site to get a lot of people's different perspectives; but if you want a very organized presentation on all the different colors and how to get them, you could look for "The Colouring, Bronzing & Patination of Metals" by Richard Hughes and Michael Rowe next time you're at the library.
But if you are looking for the blue-green patina associated with aged copper, probably the easiest way is to brush on a commercial patinating solution.
Copper Tubing
I am trying to put a green patina finish on copper tubing. My question, is it normal for the copper tubing to turn very dark when the solution is applied?
I cleaned the copper with steel wool on eBay or Amazon [affil link] .
then washed with muriatic acid ⇨
and rinsed off.
The patina did appear but am unsure about the very dark copper.
Jeff Rodkey
- Chambersburg, Pennsylvania
Why do copper domes and the statue of Liberty turn green and not black as they weather?
Natalie Hake
- St. Louis, Missouri
Because the corrosion products of copper exposed to this environment are green rather than black, Natalie. I think you'll find that copper turns brown first, then green over time.
Do the Prismacolor markers [affil link] create a nice red color on copper? I used liver of sulfur on eBay or Amazon [affil link] to make the flowers black, the second part is to use acrylic paint the closest possible in color to the metal(the black color after the liver sulfur or the copper color?); and then use the color pencils in layers.
Dolores Lago
Teaching/special ed. - Naperville, Illinois
Believe it or not, "EASY OFF" oven cleaner on eBay or Amazon [affil link] sprayed on a clean copper surface will blacken it as it dries. Use more coats as needed.
If you are making Mission style hardware, you need to get quite dark. several coats will be needed. I liked three.
W. Kimball Englehart
- Lancaster, California
September 22, 2008
