Letter 28019
Metals question for art
project
I am an artist working on a sculpture project. I am using
stainless steel for as much of the project as possible. However I may
need to use another metal for a strong pole (2" diameter x 8' tall)
to mount my project on top of. Using a stainless steel pipe may be
too expensive. If I use a galvanized steel pipe, will I risk
corrosion? And, will I be able to finish the galvanized pipe with
either a bright metal finish or a decorative paint finish which will
last for a long time? The upper part of the sculpture is a windmill
of sorts - with stainless steel blades and hubs that will be
electro-polished to a bright finish. I am electro-polishing it to get
the bright finish but I was also told it may serve to protect the
metal from corrosion. I am able to send a photo of the model that i
built for this project if that helps. The result that i am after is a
metal sculpture that will stand outside in the elements without
corrosion(losing its strength) or losing its reflective finish.
Umbeya Malley
Artist - Santa Fe, New Mexico, USA
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question or inquiry on a
different subject.
