(Banner at right cycles thru shops offering E-coating services) |
Letter 27085
To: Gloria Schwedler
The "Pros" of E-Coat are numerous, however the applicability of E-Coating most certainly would depend upon the finishes you are considering for replacement.
The "Cons" of E-Coat is that a separate bath is required for each color, however there are exceptions to this as well. Considering most tinted baths are transparent to varying degrees, the color or finish of the substrate material as well as the coating thickness greatly affects the final finish.
Regarding maintenance. A properly designed and equipped E-Coat system requires essentially the same maintenance as a properly maintained plating bath. The solutions and the system must be monitored to assure a quality finish. I think you will agree that this is true for any manufacturing or process system. Consistent color is simply a result of using the same voltage to apply the coating and replenishing the bath with the same formula of dyes and pigments that originally made up the bath.
I hope I have been of some help to you.
Edward Muldoon
- Costa Mesa, CA USA
Save
This Page (why?) - Home - ©1995-2009 finishing.com
