Letter 27051
Silver plating was very dull and not mend
I have a cyanide silver bath. Last month it dont work. I made Hull
Cell test and result of it very dull middle current to low current
and high current was soft dull. I added silver cyanide to Hull cell
bath then result its worked. But now, after I made Hull Cell test
result it dull similar as last month. I added silver but it not
worked. I think higher carbonate in bath. But I have not instrument
for analysis of carbonate. I have been wanting silver plating is work
. I dont know how to addition or edit for bath. I was to venture add
brightener but added very , dull was very.
Help me please. Thank you very much.
Tawan
lab supervisor - Bangkok, Thailand
1st of two simultaneous responses-- Jan
Tawan,
To analyse for Carbonate content you can use the following method:
Pipette a 10ml sample of plating solution into a 600ml squat form
beaker, add 300mls of de-ionised water and heat on a hot-plate with a
boiling rod. *DO NOT BOIL*. Add 10% Barium Chloride solution until no
more precipitate forms then filter the precipitate through a Whatman
Number 40 filter paper.Wash the filter paper and beaker thoroughly
with hot de-ionised water until the final washings no longer turn pH
indicator paper blue.Transfer the filter paper back to the original
beaker, pulp up the filter paper and add 200 mls of de-ionised water.
Add 5 drops of Methyl Orange indicator solution the titrate with 1.0
Normal Hydrochloric Acid while stirring the pulped filter paper with
the boiling rod.
End-point is: ORANGE to RED
Calculation: Titre mls of 1.0 Normal Hydrochloric acid * 5.3 =
grams per litre Sodium Carbonate
Titre mls * 6.91 = grams per litre Potassium Carbonate.
Nigel D Gill, B.Sc. MIMF AIEMA
MRSC
- Glasgow, Scotland
2nd of two simultaneous responses--Jan
Tawan,
Be very carefull with adding brigther in your solution. Try to
dilute some of the solution of the silver solution in a hullcell. I
belive your brigther is to high. Also what you mentioned abouth the
carbonate can also be to high.
Good Luck.
Anders Sundman
surface finishing engineer
Sweden
Perhaps I am wrong, but there are two other questions posted in
the section from Tawan from Thailand and they both relate to silver
cyanide baths.
If I am wrong, I apologise ahead of time. I just wonder if Chris
Owen was on the right track in his response in
26978, which asks about chloride
contamination. It is possible that the chloride comes from the
make-up water, but you should only use pure water, not tap water,
when making up plating baths. 27119
talks about nitrate contamination. If you have nitrate contamination,
you have a problem because virtually all nitrates are soluble so they
cannot be precipitated out. The only other route may be to
electrochemically reduce the nitrate, but this is very unpredictable.
The reduction products can range between ammonia, nitrogen, nitrite,
nitrosamine etc and the final product will depend on a wide range of
operating parameters, including the type and structure of cathode
being used.
There is now a suggestion the problem lies with carbonate. It is
well known that cyanide will produce carbonates and these are not
conducive to good cyanide plating, so this is quite possible. Your
comments in this submission suggest there is an inbalance in the
cyanide, so I would suggest you get a complete analysis of everything
in the bath and tell us what it is. Also tell us whether the silver
cyanide is a pure commercial grade or if some-one has made it up on
the cheap. Once we all know what you actually have, perhaps someone
can advise you on how to get good silver plating.
R&D practical scientist - UK
You definitely win's this month's "read between the lines" award,
Trevor, thanks!
I hadn't noticed it but you are correct that Tawan has posted 3
questions which seem to be related to the same issue, and his problem
may not be the need for removal of nitrates, or the need for removal
of chlorides, or even the need for removal of carbonates, but a
clearer understanding of exactly what may be wrong with his bath.
finishing.com
Brick, New Jersey
You're probably right, Trevor. I could very well be on the wrong
track. But, coincidentally, the 2 strangers that Tawan asked about,
chloride and nitrate, just happen to to be the 2 that are involved in
a AgNO3 to AgCl to AgCN makeup process. Tawan, what is the source of
the suspected chloride and nitrate contamination?
Chris Owen
- Houston, Texas
Chris,
I think you could be on the right track with your suggestion that
dodgey silver salts are being used. I was only offering the water
scenario as an alternative source. I am just wondering what Tawan is
actually doing and what he has really got.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
