Letter 27033
Constant current vs. voltage anodizing
There is an equation that tells a person if they are anodizing
using constant current as opposed to voltage anodizing, the time it
would take to acheive various thicknesses. Can you share this with
me?
Edward f. Yost
line operator quality control - Ramsey, MN, USA
Anodizing is theoretically by Current Density. I know a lot of
anodizers that these many volts at this much time on this type of
alloy will get you this thickness of coating; these numbers vary per
shop and all ref. current densities
Chris Snyder
plater - Charlotte, North Carolina
The following equation may help you: H = 0.4 * W * T * J/F
where H is layer thickness in microns
W is Anodic efficiency
T is time in minutes
J is total current (amperage) in amperes
F is surface area in sq.dm
(Anodic efficiency is around 65%)
Jan Prichystal
Audio-visual - Denmark
I would suggest using the 720 rule. Try using this formula:
Square feet x Amps / Square foot = Anodizing Amps
Example (500ft2 x 20 amps/ft2 = 10,000 Anodizing Amps)
Square feet x Mill Required
___________________________
Anodize Amps x 720 = Anodize Time
Example-
500ft2 x .70 Mills Required
10,000 Anodize Amps x 720 = 25 minutes Anodize Time
This should get you very close depending of course on tank temp or
part thickness.
Bruce Pfaff
- Wausau, WI
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question or inquiry on a
different subject.
