Letter 27006
Effect of aluminizing on E-glass fiber
Currently I am working on (Aluminized E-glass fiber)to check the
mechanical and physical properties, I have bonded the aluminized
E-glass fiber with polyester Norrpol 444-M888. Did the mechanical
tests (impact +tensile+ flexural) and I had strange results. In
comparison with Bare E-glass fiber,the bare E-glass fiber was
stronger %53 than the aluminized E-glass fiber, my first conclusion
was the aluminum did not have a good adhesion to the polyester. I
would like to ask you if there is way to bond these fiber to improve
the mech and phys properties. PS (I have used Epoxy and Twintax and
didn't work so far). I thank in advance for any reply.
Osama Errajhi
Composite Material Researcher - Tripoli, Libya
Hi Osamai,
Am read your search but I want answer you if you can write your
search by Arabic when Arabian people can raed your search.
Anis
- Tripoli
Ed. note: Thank you, Anis, but this website can post only
inquiries and responses that are in English. Sorry.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
