Electroplating (Electrodeposition) of Niobium
Q. Although there is reference in the literature to the plating of titanium and its alloys I have not found anything that suggests it would be possible to electroplate these metals with niobium. Is there any experience of electroplating with niobium?
"The Properties of Electrodeposited Metals and Alloys"
by William Safranek
safranek
ASM Metal Handbook
9th Edition, Vol. 5
"Surface Cleaning, Finishing & Coating"
asm_vol5old
Richard Curtis
1995
A. Niobium is not mentioned in Safranek's "The Properties of Electrodeposited Metals and Alloys", nor Faust's list of electroplateable metals in ASM's Electroplating course, or ASM's Volume 5: Surface Engineering, or the Metal Finishing Guidebook, or Durney's "Electroplating Engineering Handbook. My strong assumption is that it's not electrodepositable from aqueous solutions--but hopefully one of our readers will enlighten us both.
A. Niobium plating, in case you still interested in, go to Russian hand book 1987, F.F.Ajogin, page 310.
Cair Shishani
Khair Shishani
A. According to old Russian books niobium/ or niobium nickel alloys can be plated from solvent based electrolytes (DMF). Hope it helps and good luck!
- Zagreb,Croatia
March 2, 2010
Q. My name is Narumol. I am studying PhD at School of Chemistry, University of Tasmania. I have developed HPLC method for separation and determination of niobium and tantalum and I would like to apply this method to determine niobium and tantalum in electroplating solution. I don't know where I can find this solution. If you can give me any suggestion , it will be very useful. Thank you very much in advance   Best Regards,
Narumol Vachirapatama
- Hobart, Tasmania
A. Alas sir, there at this time seems to be no way to electroplate Niobium. And it would be GREAT if there was one, the closest I have been able to find is using molten niobium salts at 700+ degrees. and even that is seen not to be a very consistent product.
Jackson Rackham
- Tigard, Oregon, USA
June 1, 2011
Electroless plating of niobium
Q. I am not finding method of electroless plating of niobium on copper specifically? Where to I find it
"Electroplating Engineering Handbook"
by Larry Durney
EEHcover
Saagar Vijay
WSU - Detroit
January 25, 2008
A. Do you have reason to believe it is even possible, Saagar? I am not confident that it is :-)
Do you envision immersion plating or autocatalytic plating, or haven't gotten quite that far in your efforts?
Q. I am working in a research lab currently trying to plate Niobium onto magnesium and possibly copper. Currently we are able to plate a significant amount of Niobium onto magnesium however the solution we are using is cloudy (trying to resolve this now). I was curious where you found out about DMF as a possible solvent because I cannot find any related literature.
Also any advice on a complexing agents in regards to Niobium would be great
JB Crane
- Wichita, Kansas, USA
June 25, 2013
A. Solvent based niobium plating solution:
niobium pentachloride 10-15 gms/lit
benzene 500-600 mll/lit
amyl acetate 20-30 mll/lit
methanol [affil link] 300-500 mll/lit
45 °C temp.,10 mA/cm2,iron cathode/niobium anode
Dissolve pentachloride in benzene,add amyl acetate (drop by drop),when pentachloride is dissolved(light yellow colour of solution) add metahnol.
According to Russian book A.M.Yampolsky: Elektoliticheskoe osazhdenie blagorodnih I redkih metallov, Leningrad 1977.
Also, K.I.Tihonov, N.I.Agafonova: Elektroosazhdeniye metallov iz organicheskih rastvoriteli (Electroplating from organic solvent based solutions), Leningrad 1979. In Russian that is download free book (www.galvanicrus.ru webpage)!
Q. We would like to know maintenance method for each material.
Tony June (Mr.Tony)
chemical engineer - South Korea
December 23, 2024
thumbs up sign Hi Mr. Tony.
That seems to be a tall order because Goran was quoting from a book, not experience. But you apparently know something about this subject, so please share it with us while awaiting a possible reply. Thanks!
Q. I have a project that involves coating Niobium onto Tungsten. Is electroplating or electrodeposition a possible route or are there fundamental reasons it won't work?
JEFFREY BREITSCHOPF
Graduate Student - College Station, Texas
July 19, 2017
A. Hi Jeffrey. It appears that conventional electrodeposition of Niobium (i.e., from a water-based plating bath) will not work but that, to some degree, electrodeposition from molten salt or dimethylformamide (DMF) solvent may be possible. The issue would appear to be that niobium (like aluminum and titanium) is too active, such that hydrogen will be split off from the water and deposited in preference to the deposition of niobium. Good luck.
