-----Solutions to problems electroplating ABS-PC, polycarbonate, PBT, & other plastics
ABS (acrylonitrile butadiene styrene) is the plastic of choice for electroplating, and the most widely used, because it is a mixture of 3 different resins, one of which can be etched away, leaving an ideal sponginess to the surface allowing good "seed" sites for initiating the plating, while offering great "tooth" for outstanding adhesion.
The site has numerous threads about plating ABS (please search the site), but sometimes other plastics offer the needed properties for an application; this thread is about plating those other more difficult to etch & metallize plastics.
Q. We are not able to get finish at mating line of ABS and PC 2K moulded part. It is either skip or overlap plating .
What should be parameters of pretreatment baths ?
Manager - Pune India
November 24, 2025
? Hi Vinod.
Can you send <pics for posting> please. I assume the component is a PC-ABS blend and by mating line, you mean where two halves of the mold come together? (You're not talking about a component where a portion is ABS and another area is PC I hope and they are bonded together I hope).
I don't quite understand what you mean by "overlap" in this case therefore.
ABS = acrylonitrile butadiene styrene
PC = polycarbonate
Q. I applied to metallize ABS/PC blends using the same methods to ABS, but I can't obtain any adhesion. Could someone help me?
Norberto martin- Buenos Aires, Argentina
A. Plating on ABS/PC is possible but you need a special preconditioner before the chromic etcher. Ask your supplier about it.
Sara Michaeli
Tel-Aviv-Yafo, Israel
Etching and pre-etching specialty plastics
PBT (polybutylene terephthalate)
Q. I am an amateur researcher in the field of electroplating. Would be grateful if you could give me information on the following: What chemicals/other methods can I use for pre etch and etch of --
"Plating of Plastics with Metals" by John McDermott (1974)
avail from AbeBooks, or Amazon (rarely)
"How to Electroplate Non-Metallics" by Warner Electric Co. (1967)
[more appropriate for hobbyists than for industrialists]
avail (rarely) from eBay, AbeBooks, or Amazon
1. Lexan 143/123 (polycarbonate)
2. Cycoloy C1200 HF (PC-ABS ALLOY)
3. Xenoy1731 (PC-PBT ALLOY)
4. Xenoy1102
5. Lexan 943
Please give me information on the chemicals involved and process chemistry of the electroless plating of metals on the above mentioned engineering thermoplastics ⇦ Answer?
- New Delhi, Delhi, India
What is the chemical action of chemicals like NMP or CAS in the pre-etch of PC-ABS? Any chemical equations at hand? What are the other economical methods of plating PC-ABS (CYCOLOY 1200HF)? ⇦ Answer?
Shobhit Mehrotra [returning]plastics - Gurgaon, Haryana, India
2nd Request
Flaking EMI Coatings
EMI = electromagnetic interference [shielding]
Q. We are looking for advise on achieving good gold/silver EMI coating adhesion on GE plastics-Velox 420, 30% glass reinforced PBT resin (polyester). Our customer has experienced coating flaking off when submitting the coated unit to temperature cycles ... not sure what temperatures, though. I am trying to qualify a new source for the EMI coating, but lack the base knowledge of the process. Any help is much appreciated. What could be causing the flaking of the coating? What are the recommendations for good adhesion?
Miguel Vallejo- Camarillo, California, USA
A. Hi Miguel. A starting point in troubleshooting is to look at the back of the peeled foil and the part of the workpiece which has peeled, and determine what layer separated from what layer. While the plating sometimes peels completely, there remains the chance there was peeling between the electroless nickel or other prepates and the silver or gold.
But assuming that the plating peeled all the way down to the plastic, first, you'll want to check with GE to make certain that they consider Velox 420 a "plating grade" of resin. Second, you'll want to align yourself with a supplier of the process chemistry who would have the required knowledge base, or a plating shop who is good at this application.
Plating on plastics, especially on hard-to-plate plastics, is something that is learned from years of experience after acquiring a good deal of book knowledge. I don't want to make it sound like black magic, but there are many critical steps, any one of which can lead to this poor adhesion or appearance. While inadequate etching may be the first suspect, it's far from the only one.
Some plastics, and Velox 420 may be one of them, require special addition agents like talc, and/or mechanical roughening, for adequate adhesion.
Pre-Etching Suggestions for PC-ABS
Q. I would like to plate on a plastic containing ABS + polycarbonate (40:60). Please suggest a suitable etchant. Will chromic acid + sulfuric acid work?
Vijaykumar S. Ijeri- India
A. Dear KUMAR,
Chromic/sulfuric acids etchant will work for ABS/poly carbonate but to increase the adhesion it is better to use pre-etch solution. For polycarbonate it has the following composition:
tri ethanol amine 100 gm/l
ethylene glycol di ethyl ether 80 gm/l
sodium hydroxide 150 gm/l.
Best regards
PLASTICS ELECTROPLATING - CAIRO, EGYPT
A. That mixture should do the job. I suggest you run it at about 50 °C and etch for between 15-20 minutes. Make sure you destroy all the hexavalent chromium before going into the plating tanks or it will blister, peel, skip plate and generally fail. I suggest you reduce the chromium to trivalent chromium by washing in sodium metabisulphite for about 10-15 minutes, followed by thorough washing in counterflowed clean water.
Q. Can I use some organic based Chrome reducer like Hydroxylamine HCl, Hydrazine Sulphate, Oxalic acid instead of sodium metabisulphite? In your opinion, which is better?
Vijaykumar S. Ijeri [returning]- India
A. Hi Vijaykumar
Way back when, hydrazine was used in the Lancy 'Integrated Treatment' systems, but hydrazine is dangerous. I'd stick with the sodium metabisulphite that Trevor suggests. The organic chemicals you listed might work, but organics can have a profound effect on subsequent plating steps so I'd suggest avoiding such experimentation until you have a proven process you can revert to. Too many variable can make troubleshooting very difficult.
Q. I face problem of adhesion to metallized reflectors in ABS,PC. The reflectors are directly metallized after molding without any pretreatment or base coat.In peel off test the reflector fails in some areas only. I would like to know what is plasma treatment and how is it done? Mahendra- Nashik, Maha, INDIA 2002 Ed. note: we may be misreading, but it sounds like you are vacuum metallizing the plastic rather than electroplating it? Nothing wrong with such a question, of course, but we don't want to confuse new readers who are here to learn but because of their newness might easily get confused 🙂 A. Plasma discharge is a process whereby a plasma is struck in a low vacuum. The vacuum is typically less than 250mT. The most useful gases for ABS and PC are oxygen, nitrous oxide or air. Suitable powers for polymer activation are in the order of 80-120W and processing times between 1 and 5 minutes, depending on the polymer. ![]() Trevor Crichton R&D practical scientist Chesham, Bucks, UK |
Q. We need Nickel chrome plating on ABS/PC injection moulded component. The moulded component is good. But during plating, we notice some black pads and streaks forming. How do we avoid this? Which is the right chemistry for this? What are the basic surface preparations before plating? ⇦ Answer?
RAMANAND KINI- India
Q. We have tried to chrome a PC-ABS mixture with no success. I am wondering how will the outcome, appearance, durability and adhesion be for chroming Glass Filled ABS?
Thanks for your help,
consumer products manufacturing - Hong Kong
? Hi, Marbo.
Electroplating onto PC-ABS blends is a more highly developed science/process than plating onto glass filled ABS, so switching the substrate to glass-filled ABS due to plating difficulties with PC-ABS is not the way forward 🙂
Have you previously enjoyed success plating pure ABS or are you just trying to get into plating on plastic? If you've had such previous success, and you are using a plating grade PC-ABS resin, prior postings and future responders can probably help you with the issue, but if you are trying to start from scratch you will definitely need to hook up with a plating process supplier, or at least an experienced consultant.
A. Marbo,
It is possible to plate Ni Cr over PC ABS blends. The etch is critical. So is the selection of a Plating Grade PC ABS blend. Etch in 450 gpl CrO3 + 300 GPL H2SO4 at 70 °C for 6 to 10 minutes. Or more if needed. This is the major aspect. Rest is similar to your process already being followed.
Asif Nurie [deceased]
- New Delhi, India
A. By mechanical weakening, I presume you mean the chrome plated plastic is more prone to failure than the unplated counterpart. This effect is well known in the POP sector and initially caused a lot of problems. Many of the POP practitioners have got over it in their own way, but one way I know of is to use only a very thin layer of electroless copper or nickel, thicken this with about 5 microns of low stress copper, followed by about 15 microns of low stress nickel. Decorative chrome can be put on top of this. Hopefully, others will give alternative methods of increasing the mechanical strength of plated plastics, as I cannot be sure this is the best solution!
A. Dear Mr. Tse,
Plating ABS/PC is too complicated to discuss here in detail. Contact the supplier of the plating chemistry, as they should be able to help.
- Hong Kong
YES, Jonathan, plating of ABS/PC is quite complicated!
YES, it's advisable to contact the supplier of the process chemistry because the process involves many steps and they are inter-related
But too complicated to discuss here? Heck NO !
Masking issue with Chrome Plating on PC/ABS
Q. Hello Friends,
I am a mechanical design engineer with a double-shot part (30 mm x 30 mm x 30 mm) that needs to be electroplated with 20 micron Copper + 10 micron Nickel + 0.3 micron Chromium (satin finish).
The complication is the double shot part being PC clear (inner shot - not to be plated) and PC/ABS (outer shot - to be plated). We have worked with many platers in Asia Pacific as well as Europe and the main problems are:
1) Unwanted plating on the PC clear. Since the etchant not only dissolves the butadiene but also attacks the PC in both PC and PC/ABS, both PC and PC/ABS become plateable. Can we just remove the butadiene if the PC% in the PC/ABS is not high? We do have stringent automotive service requirement for the plating. ABS material for the outer shot is not considered because of a 100 °C/6hrs service requirement.
2) Blistering after -35 °C to 85 °C temperature cycle test at 12 hrs/cycle X 50 cycles.
Any advice?
Any recommended plater?
Best Regards
Mechanical Engineering - Singapore
? Have you tried stop off paints to protect selected areas?
Q. Thank you Mr Marrufo for your input.
No, we did not consider masking yet due to the extra processes required. We do need the PC inner shot to remain clear ... is there any masking paint and solvent (to remove the paint) that you can recommend?
The fact is that we are able to get good quality parts. However the yield is either low or not consistent.
? Have you tried to use preplating strips?
Lee [surname deleted for privacy by Editor]- Taipei, Taiwan
Q. Hello Mr Lee!
The main problems we faced are:
1) if the etching is too strong, PC will also be roughened --> becomes slightly plateable --> chrome over-plating
2) if etching is too weak, PC/ABS not fully etched --> skip plating such as pinholes, etc.
Can you tell me more about the function of preplating strips and how they can help?
A. I am having similar problems masking a totally ABS moulding! On the blistering side of things you must ensure that it is a plateable grade of ABS, ensure that there is no pigment, make sure it is not 're-grind' material and also that the surface is not stressed. Try to get more copper on the part as this seems to act as a dampener in thermal expansion. Also ensure that the initial etching material is not at end of life.
Chris Love- United Kingdom
Ed. note: Thanks, Chris. Indeed OEMs plate copper between the electroless nickel and the electrolytic nickel on auto grills and such for that exact "thermal expansion dampener" reason.
Plateable Lexan grade PC?
Q. We would like to know what plateable grade of Lexan or polycarbonate or other industrial grade of plastic resin such as PBT, etc. ... if ABS is not considered.
KEN WONGlighting plastics - Hong Kong
A. Virtually anything can be plated, Ken, but the usual problem is that excellent adhesion is required, and that can be difficult to achieve between plastic and metal unless excellent "keying" through etching is possible. ABS is favored because it can be etched in a way that leaves a sponge-like surface for great adhesion. I would suggest looking at "Standards & Guidelines for Electroplated Plastics", which will give readers a fuller understanding of the issues and help them make a decision on how to proceed.
There are ways to electroplate polycarbonate via additives and surface roughening, but as far as I know, none offer durability and adhesion comparable to plating on ABS. Then again, firms like Ekem specialize in processes for plating on polycarbonate and know more about it than me.
Chrome Plating on Valox
Q. I would like to apply a mirror like surface in mass production on an injection molded plastic part (say 10 cm2 surface area) that is planned to be made from Valox 420 SEO. Would chrome plating work? Is it possible to plate only one side of the part? Where can I read about the process in detail? What is the cost I should expect per unit? Would there be any alternative technology? I appreciate your answers in advance.
Lajos Reichbuyer - Hungary
April 30, 2008
A. Hi, Lajos. There are many competing technologies for applying a shiny metallic-looking coating. The choice depends on how shiny, plus how much wear resistance and adhesion is required. The majority of brightwork on automobile headlights and taillights, protected from the environment is probably vacuum metallizing and relatively cheap when done in volume. But on grills and exterior plastic parts it is chrome plated plastic, which is relatively very expensive. but for top adhesion you need a plastic designed for that, like ABS (I don't know if Valox is selectively etchable like ABS to bring out excellent "tooth"). Other possibilities include chrome-look paint. Single-sided coating should not be a problem with any of the technologies.
A. Valox 420 SEO is a PET-PBT blend of polymers with 30% glass filler. It is possible to etch PET/PBT, but it takes some very aggressive processes. I would suggest that 420SEO is not the best material for metallising, but it will be pretty strong!
I seem to recall that GE, who originally marketed Valox, would supply it with a range of fillers, including calcium carbonate.
I would suggest that you contact the current suppliers of Valox (I believe GE recently sold off its plastics division to SABIC) and see if they still do the filled version of Valox and if so, what fillers are used. Depending on the fillers, you can pre-select your etching process to meet your needs.
Your other questions are very open ended and need to be addressed with some technical knowledge and understanding of end-uses. I would therefore recommend you take Ted's advice and get some background information on plating plastics before wanting a long series of information on a complex topic. I am sure you will be able to achieve your highly reflective surface, but you need to know what your budget is and what the product's end use will be
Swellers for PC
Q. We tried several commercial swellers for PC, and adhesion is bad. Can anyone suggest any solvent or mixture of solvents suitable to swell PC ?
We are doing plating on plastics, commonly ABS. We have a new project plating with 100% Polycarbonate. With modified chromosulfuric etch (CrO3 450 g/L + H2SO4 450 g/L), it does not etch/attack the PC. Subsequently, no electroless nickel adhesion. We tried to increase the palladium concentration in the activator, but in vain. We learned that there is some kind of sweller (water soluble solvent) that might dissolve the PC and then makes the PC to be etched by this modified chromosulfuric etch. That's why we need the sweller for pre-treatment on polycarbonate. Thank you for your attention. Thanks. ⇦ Answer?
plating engineer - Hong Kong, China
March 8, 2009
Over-etching of PC material
Q. We have tried cutting the etch bath after the concentration went to high and we are still seeing over-etching in our plastic. The bath is in range on everything. Is there something else I could try to fix over-etching?
Josh DorrisPlating Process Engineer - Farmington, Missouri, USA
July 17, 2013
A. It could be temperature, what with the warm summer weather. Maybe try running the parts in the morning. You can also use less bath time but I suppose you've tried that. What you might be seeing is varying base material. That's pretty common for the type of material you are working with. You may need to write an ECO or allow a temporary deviation and try a less concentrated solution (below approved range) but that would need to be tested. Good luck, you can do it. We're all behind you.
Blake Kneedler
Brittleness after plating of PC/ABS
Q. I have an application of a chrome plated latch handle for a console. They have designed snap fit features on this part that snap into the pawl. The issue is the parts are cracking and breaking in the field at the snap fits. There is also a painted version of this that has no issues. I do notice a difference in the brittleness/stiffness of the snap fit areas on the chromed parts. Under a microscope I can see cracking occurring when the snap fit features are flexed that looks to be deeper than the just the chrome thickness. I understand that the etchant attacks the Butadiene, but does it also attack the PC? If so, is that the reason for the brittleness? ⇦ Answer?
Kris CabanillaAutomotive engineer - Troy, Michigan - USA
April 23, 2015
Spotty speckles on PC+ABS chromed parts
Q. Hello everyone!
We have a PC+ABS moulded part which is electroplated at one of our suppliers. They have the standard electroplating process including copper, nickel and chrome layers.
Recently, we had a very poor yield due to spotty speckles. It might not be the technical term, but this is the the fault name used between ourselves and the supplier. The supplier is saying that the root cause is down to the moulding process and we are saying that the root cause is the plating process.
The speckles are less than 0.1-0.2 mm in size and they are usually in a cluster formation.
- Buckingham, UK
February 4, 2020
A. Dear Ana,
If the plater says it must be the moulding and the moulder says it must be the plating, you don't have a root cause, you have an argument.
So some questions for you:
What are "spotty speckles", exactly? From your description it's hard to tell if they're little pits, blisters, discolouration...
Do these problems always appear at the same stage in the plating process or the same region of the parts? Are they genuinely all the same type of defect or have people gotten into the habit of labelling all small defects under the one category?
Has anything in the moulding process changed? Can you document this?
Has anything in the plating process changed? Can your supplier document this?
How are parts packaged and handled as they're moved between you and your supplier?
- Gloucestershire, UK
Peeling Problems
Q. We are doing chrome plating on PC+ABS for automotive parts and we received the complaint from the field that complete coating got peeled off from the substrate; so kindly let me know what are the causes for this and how can I get off from this issue.
Kapil Chinchmalatpure- Pune India
December 15, 2021
A. Hi Kapil. Unfortunately, many things can go wrong and lead to peeling. But I would suggest starting by reading about etching of PC+ABS on this thread and getting back to us with follow-up questions.
A. I assume you are following the standard procedure for POP including EN/EC, etc.
ABS PC needs a more concentrated and more etching time than ABS.
Sara Michaeli
Q. Skip plating observed on PC/ABS part but ABS moulded parts plating good what reason
- India
January 30, 2025
A. Hi.
Although plating is complicated and there could be other causes, it sounds like the first things to investigate are how much PC is in the blend, and whether the pre-etch and etch are adequate for it.
If you made it all the way through this thread, you may also be interested in this related one:
• Topic #18069 "Plating on Plastics: ABS vs PC, Nylon, & other plastics -- What substrate to use?"
