-----Potassium Hydroxide for activation of thru-hole PCB plating
I was interested to see if anyone had heard of using a potassium hydroxide solution as an activator in through hole plating and the process by which this occurs. Thanks, Josh
Joshua C [surname deleted for privacy by Editor]Virginia Tech
Joshua, Actually, potassium hydroxide has high conductivity relative to sodium hydroxide. So potassium hydroxide based formulations have relatively high throwing power, often used in thru-hole plating. I do not think it is a real activator. Ling
