Letter 2684
Removing electroless Ni from steel
I am trying to remove electroless Nickel coating and Copper strike
from steel without corroding steel surface. So far my results are
very inconsistent: parts cleaned in the same acid vat never look the
same. My acid bath is basically Hydrochloric/Sulfuric acids at 1 to 3
ratio with some surfactants and wetting agents. What am I missing in
this process?
Thank you in advance,
Nina
Nina Geller
- Memphis, TN
Nina, You can try the following formulation for your application:
Sodium hydroxide 7-9 oz/gal Ethylenediamine 15-17 oz/gal
m-Nitrobenzene sulfonic acid 5-7 oz/gal temperature 165-175 F Good
luck! Ling
Ling Hao
- Grand Rapids, Michigan
Nina Geller Memphis Tn: I like a product called B-9 By
Metalx Inc., across the
board its the best that I have used
Chris Snyder
plater - Charlotte, North Carolina
Please also see our FAQs on
Stripping of Electroless Nickel.
Finishing.com Inc. - Brick, NJ
