Letter 26071
Seeking firm to strip rubber from metal
parts
Seeking firm to strip rubber (buna n) from metal, butterfly valve.
Valve is approx. 5 lbs. cast with a .010 layer of rubber molded to
the surface. Some possible techniques; blasting, heat treatment,
chemical soak, etc. ... Treatment cannot damage the metal as metal
component will be re-used. Require to reclaim approx. 300 valves.
Cliff O [last name deleted for privacy
due to age of posting]
mfg. - Bensalem, PA, USA
Dear Reader: there is no provision for public reply to this
particular letter because it is not a technical question but a
commercial inquiry to which our advertisers will reply in private
- Post a new
question on a different subject.
