Letter 25895
Gold plating an aluminum sword
I am an artist, and I have been crafting a decorative sword for a
while now. The sword is very important to me, because it symbolizes
me. I have been reinventing the metal working process during the
sword's construction. The blade is made of construction grade steel
and has been chrome plated. I cast an aluminum handle around the base
of the blade. When the blade was plated the electrode had to be
attached to the aluminum handle. Unfortunately, the current which
passed through the handle oxidized the piece of the handle below the
electrode. I am in the process of trying to repair the oxidization
right now. Next, I want specific regions of the handle to be gold
plated, but I am concerned that the handle, or worse the blade, will
be damaged when electricity passes through the sword. I would like to
know a few things. I want to do as much of the work as possible. Is
there a way I could plate the handle safely myself? How can I clean
the residue from the handle if it needs to be plated professionally?
I would also like to do this as cheaply as possible. Any suggestions
y'all have would be greatly appreciated.
Thank you:)
Brandon Christeson
artist - Plano, Texas, USA
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question or inquiry on a
different subject.
