HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 25351
Need undercoat and topcoat paints for vacuum metalizing aluminum and plastic
RFQ: We are looking for top coat for high vacuum metallization process, with good adhesion and scratch resistance. The materials it will be applied to are plastic (ABS, PP, PS), sheet iron, polyester and aluminum.
Melih U [last name deleted for privacy by Editor]- Istanbul, TURKEY
^- Sorry! This RFQ is outdated -^
RFQ: We have a problem in vacuum metalizing aluminum on nylon (polyamide) and thermoplastic-polyurethane (tpu) plastics parts.
We are looking for under-coat and top-coat paint for vacuum metalizing aluminum on nylon 6.0 and tpu plastics material/parts. The paint must be flexible and have good adhesion strength between aluminum and plastics material. We hope there is someone can help us.
Irwan N [last name deleted for privacy by Editor]plastic plating - Jakarta, Indonesia
RFQ: Dear sir,
We are doing vacuum metalizing on plastic gift items & automotive reflectors in Karachi Pakistan. We are interested in buying basecoat & topcoat lacquers for applying on these plastic materials. A.B.S.,POLYSTYRENE, HI-IMPACT P.C. We need also basecoat lacquer for polypropylene. Kindly give your best cnf prices with literature.
Thanks & regards,
Zeeshan [last name deleted for privacy by Editor]plating - Lahore, Pakistan
RFQ: Hi,
I need a supplier for lacquer to do primary and finish coat before and after metalizing plastics. Prefer supply from Turkey.
Mohamed K [last name deleted for privacy by Editor]vacuum metalizing - Damascus, Syria
RFQ: Need topcoat for vacuum metalizing coating. Description:
Nitrocellulose based lacquer to be used as top coat for vacuum metalization of PS and ABS product. It serves as a binder for dyestuff as well as a protective coating for the metalized aluminum film.
Specifications:
Appearance:-------Slightly Yellow Clear Liquid.
Specific Gravity (20 'c):----APP.0.86.
Viscosity.(Iwata cup 25'c)Sec:---9-11.
Solid (150 'c x 30 MIN),%:---12+ 1.
Solvent:---N-Butanol,Diisobutyl Ketone.
Operating Method:-- Spraying or dipping.
Applied Material PS,ABS
Drying Directive:--60'cx120 MIN.
We hope that above specification will help you to understand our required material.
We are waiting for your early reply soon.
Best regards,
Saleem A [last name deleted for privacy by Editor]vaccm metalizing coating - Gujranwala, Punjab, Pakistan
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
