Designing a rectified supply
I'm having to design a rectified supply for electroplating. This supply has a current is not inverse. µin= 220V three phase f=50 hz, Uout=10-24v, Iout=800A, stabilizing current for supply. I hope everybody can help me as soon as possible. Thanks so much!
Sdaitenus- NH, Viet Nam
If available, look for the IEEE handbook on electrical engineering and look for rectifier designs. (How much do you know about electricity/engineering?) Since you need the current stability, the circuit complexity increases a lot. I would use a proper transformer to step down voltage that will give you step up current, then a bridge rectifier with a filter to reduce ripple, then current stability and voltage variation circuit. Rest you have to figure out!
Mandar Sunthankar- Fort Collins, Colorado
