Removal of clear coat from aluminum mag wheels
I have a 88 K-5 Silverado and the clear coat on the aluminum mags turned yellow and it looks like crap. I have tried rubbing compound, Blue Magic, with cloth wheels, the rubbing compound worked on some parts but not on all the finish looks partly good but mostly yellow. I also tried gas, steel wool, naval jelly, brake cleaner, brake fluid, alcohol, toothpaste, nail polish remover, and injector cleaner. I want to clean up the mags but I don't want to scratch the surface. I can't seem to get a consistent finish. I would appreciate any advice, or anything that I haven't tried.
Thanks in advance,
Tim Samuels
hobbyist - Scranton, Pennsylvania
September 12, 2009
Hi, Tim. It's nasty stuff (based on methylene chloride) that should only be used with great ventilation and while wearing goggles on eBay or Amazon [affil link] and rubber gloves on eBay or Amazon [affil link] , but Aircraft Stripper will remove nearly any paint or clearcoat. Good luck.
