Zinc protection during mfgr process
We are looking for a coating to use during the mfgr. process of zinc pipes for the organ--at this time we use a coating of gum but it eats into the metal leaving a very unattractive color after the gum is washed off-many times these pipes are in an exposed setting and the discoloration is most unattractive--any help in this matter will be greatly appreciated thank you
Pam Lawson
pipe organ mfgr. - Highland, Illinois, USA
A chromate conversion coating would solve you problem. they are available that produce a clear bright protective coating (Very thin)or a yellow color (more protective.) However the chemicals are considered hazardous, and chromium waste must be treated before discharging into a sewer. A number of suppliers have these available.I suggest that if you don't want to become involved in the wet chemistry in your plant, contact a local electroplaters, most have this type of process in their plant.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics"
           and "Plating ABS Plastics" eBay or AbeBooks affil links])
