-----Heat resistant paint for mantle
I have a mantle that sees a lot of heat as I don't have a blower in my fireplace. I was wondering if there is a heat resistant paint that could withstand high temperatures without causing the paint to peel and crack after a years use?
Thanks Kevin
- Versailles, Kentucky
Hi, Kevin. There are all kinds of
high temperature paint
[affil link] from engine paint to brake lining paint to
stove paint
. The problem will not be so much finding one as finding one that you'd like your mantle done in 🙂
