Corrosion control for copper with benzotriazole
Can we use benzotriazole as additive in polymer of creating the copper protection film.
Vivek Virkarpacking material supplier - Mumbai, Maharastra, India
Hi, Vivek. Sodium benzotriazole
[on
Amazon]
is a well known preservative / corrosion inhibitor for copper and it has been added to some lacquer products like Incralac
[on
Amazon]
or Permalac [adv: Permalac on
eBay]. So the general answer is yes, but whether it is compatible with your other materials is an open question. Good luck.
October 13, 2009
Copper Finish for Thermal transport
Q. My company currently finishes our copper heat spreaders with a nickel plating to prevent corrosion.
My colleague and I have been searching the net to determine if there would be a better finish for the copper.
We require a finish that would not inhibit the thermal transport properties of the copper heat spreader. Some have suggested a benzotriazole finish. Is this a better finish than the nickel plating? Does it add any significant thickness to the part?
Thanks in advance.
- Rancho Cucamonga, California, USA
July 7, 2014
A. Hi Cory. Benzotriazole is a temporary tarnish inhibitor. The thickness would be millionths of an inch. If the environment is benign it probably has a chance of working for a while, but its corrosion resistance in anything worse than a climate controlled room would probably be minimal. Good luck.
July 2014
