finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 24108
SIMPLIFIED PRETREATMENT FOR POWDER COATING
I'M USING THE SEVEN CHEMICALS TO CLEAN THE MATERIALS BEFORE COATING THEM.
I WANT TO KNOW IS THERE ANY NEW CHEMICAL FOUND THROUGH WHICH I CAN INCREASE THE PRODUCTIVITY AND ALSO REDUCE TIME AND ALSO INCREASE QUALITY.
THANK YOU VERY MUCH
DILIP ISHWARBHAI PANCHAL
POWDER COATING - BARODA, GUJARAT, INDIA
Dear Mr. Panchal,
If you are using the seven stage pretreatment, we presume you are using zinc phosphating. Now, if your component contains rust, then this method is necessary.
In case the components are without rust, and the customer does not have a requirement for zinc phosphating, then there are single stage, no-rinse single tank pretreatments in the US and Europe which can do pretreatment in one stage.
However, they have not taken off well in India, primarily due to rust problem.
Sandeep Kundra
manufacturers of metal pretreatment chemicals - Bombay, Maharashtra, India
Where can I find out more about these one step pretreatments that are used in Europe for rust free mild steel?
Jerry Jaksha
- Rio Rancho, New Mexico
October 17, 2009
Hi, Jerry. All of the manufacturers of pretreatment chemicals, like Chemetall, have one-step pretreatments in their repertoire.
finishing.com
Brick, New Jersey
