Letter 2565 Seeking Nylon coating service- We want info regarding Nylon coating done to be done in India on metals.
Seeking Nylon coating of cast iron components . We seek vendors in China which can carry out nylon coating on our cast iron components size approximate 600 mm x 600 mm x 300 mm maximum. Please contact us direct regard terms and details.
Seeking Nylon coating of wire . SEEKING INFORMATION ON NYLON COATING ON M.S. WIRE OF DIA. 0.65mm TO 1.2mm WITH COATING THICKNESS OF APPROX. 0.035mm COATING SHOULD NOT CRACK/PEEL OFF WHEN WOUND ON ITS OWN DIAMETER.
Seeking nylon-like coating material . What I am after is a material (similar to Nylon 11) but has a system that creates a bond between the coating material and the steel item being dipped . The product I have heard about is for outdoor conditions.? Does anyone know what this product is ??.
Seeking Nylon coating of wire [Chennai, India] . Need details for Nylon Coating of Galvanised/stainless steel wires. Coating to be adherent, scratch resistant and not peel when the wire is bent.Coating thickness should be around 0.05 mm .
Dear Reader: Sorry, but this particular Commercial Inquiry / RFQ is outdated.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
