-----Question about phosphate coating
Hi
I am a researcher working on plasma nitriding at phophate coated spring wire in Korea. However, I can't achieve nitriding on wire due to phosphate coating.(cating thickness <<1um)
would you recommend me method to remove phosphate coating?
thank you
Jong Kwakinstitute of advanced engineering - Korea
Remove phosphate coatings with the following:
5% by weight chromic acid in deionized water.
Temperature = 70 - 75 °C.
helicopters - Fort Worth, Texas
Dear Mr KWAK
The advice you get from our peer Mr Greg will passivate the metal and you will not succed to make your plasma coating because of the passivation problem
My suggestion is as follows:
A.Acidic Removal :Every strong inorganic solution removes phosphate coating. you can choose between Phosphoric Acid 10% cold to 40 °C , or Sulfuric Acid 5-10% solution cold to 40 °C . Hydrochloric Acid 10% can do the job but not recommended .
The time take for those removal action is 5-10 minute.
B. Alkaline Removal :Your can use solutio consist of 5% Sodium Hydroxide hot at 85-90 °C and after 10 minute the coation will be removed completely . (Be carefull its not convinient solution!)
Yours Sincerely
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
