-----Hard chrome is peeling
We are associated in supply of turnkey chrome plating system for a large piston ring manufacturer in India. We are presently facing problems in hard chrome plating SGiron (spherodically oriented graphite iron)rings. Presently we are using a sulfuric acid etch and plating the componets in a caatalytic chrome bath of 250 gms per lt. Presently there is a peeloff of the plating. Can some one help in reducing the peel off by giving a proper process advice.
T.S.NEELAKANTAN- Bombay india.
Sounds like you are not cleaning the part surface well enough, or you are not giving the parts enough reverse current etch before the plating process.
Robert Tygart Jr1998
