     No Pop-ups! No Spam!
no_pop_no_spam
HomeFAQsBooksHelpWantedsForum  ltr 20451
Serious Education ... plus the most fun you can have in metal finishing.
Properties of Al Alloy A-356
(2003)
Q. Sir,
I am doing a project on "Analysis of Aluminium Alloy Wheels". I would like to know the properties of Aluminium Alloy A-356 especially Young's Modulus, Ultimate Stress, Density and Poisson's Ratio.
VarathaRajan.R
- Vellore, Tamilnadu, India
(2003)
A. Properties for Aluminum A356.0-T6, Sand Cast*
Density 2.67 g/cc 0.0965 lb/in
Tensile Strength, Ultimate 234 MPa 33900 psi
Tensile Strength, Yield 165 MPa 23900 psi 0.2% offset
Elongation at Break 3.5 % 3.5 % in 50 mm
Modulus of Elasticity 72.4 GPa 10500 ksi (Tension)
Poisson's Ratio 0.33 0.33
*Tensile strength and elongation values are slightly higher for Aluminum A356.0-T61, Permanent Mold Cast. Data from www.matweb.com
Ken Vlach
- Goleta, California
contributor of the year
Finishing.com honored Ken for his countless carefully
researched responses. He passed away May 14, 2015.
Rest in peace, Ken. Thank you for your hard work
which the finishing world continues to benefit from.
October 4, 2013
Q. Was wondering the shrink rate of Al 356? I'm sand casting and need the percentage I need to make my model knowing it will shrink In the casting process
Bryan Blaha
skateboard manufacturing - Palos Park, Illinois
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2016 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
