Availability of english translation of Japanese Aluminum Anodization standards
Looking for english translations and availability of the following Japanese JIS Aluminum Anodization Specs
JIS H 8602 Coated Anodic Oxide Compound Film of Aluminum and Aluminum Alloys
JIS H 8681 Testing Method for Anti-corrosion properties of Anodic Oxide Film of ALuminum and Aluminum Alloys
JIS H 8682 Testing method for Anti-friction properties of Anodic Oxide...
JIS H 8683 Testing method for the Extent of Sealin for ANodic Oxide...
JIS H 8684 Testing method for Resistance to cracking caused by irregularities of anodic oxide film...
JIS H 9500 Standard procedure for Anodic Oxidation of Aluminum and Aluminum Alloys
JIS H 9524 Standard Procedure for coated anodic Oxide compound film of Aluminum and Aluminum Alloys
Gary Escher
I would try Dr. Toshihiko Sato or Kyoko Kaminaga, Hokkaido University, Japan, both of Anodizer's Plaza (see our WWW links for their last known address).. If not there, try Alutopia =Aluminum + Utopia Magazine, published in Japanese by Kallos Publishing Co. Ltd. phone (03)3562-5736, fax (03)3561-7080.
Perhaps Professor Sato can assign the task to one of his students, given an appropriate grant.
