Letter 2107
Hardcoat
having,promblem color matching hardcoat.very tight range,for
color.must be a medium grey,and,thickness of 0015-0017. current
density is used,and we control the time.aare there many factors in
the process. time,current density,bath makeup,racking. parts,are
approx.1 sq. ft. in area. thank you, stan
stanley vilakis
Stan,
It is a tough job.
What kind of material are the parts you want to anodize? Hard
coatings on aluminum alloys usually have intrinsic cplors, so they
are generally dyed in black color. If you want a medium grey color,
you need a clear hard coating using special process with proprietary
additives. Although raising temperature might help a little bit, it
will reduce hardness and could cause burning problem, especially for
2000 series and 7000 series.
Ling
Ling Hao
- Grand Rapids, Michigan
The factors you mention are important and along with tank
temperature, part temperature, and agitation are all inter-dependent.
Note the term part temperature. Agitation must be uniform throughout
the tank to maintain the parts at the same temperature. This is
especially true if you are using high current density, e. g. 36 asf.
Hopefully your ramp up is automatic.
You didn't mention the alloy but there is one factor you may or
may not have any control over: alloying elements affect color, and
the content of the alloying elements of a particular alloy can vary
quite a bit. For example, the silicon content of 6061 is listed as
0.4-0.8%. Silicon is one element responsible for turning hardcoat
grey. We could also talk about the importance of consistent temper,
but you get the idea.
Those of us who have been involved in color anodizing for many
years learned very early to establish not one color standard, but
two- an acceptable light and an acceptable dark standard. AAMA has
established this as standard practice in their specifications.
Considering all the variables you need to control, and the likelihood
for color variation, you may need to establish this practice.
Phil Johnson
Madison Heights, Michigan
