Magnetic Shielding Coatings
I am looking for a spray-on coating for plastics (ABS) that will effectively shield low frequency (60-1200 Hz) magnetic fields. Field strength reduction desired is about 25dB.
Chris Wiegel
engineering - Woodinville, Washington
Acheson Colloids and Spraylat both make EMI/RFI coatings that would be suitable. We've had good results with the Acheson products in particular, but use both.
Michel Moninger
- Sarasota, Florida
I kindly request more detail about "Magnetic Shielding Coating".
Dr. Nurettin UMURKAN-
yildiz Technical University - Istanbul - TURKEY
Need Magnetic Shielding Coating I am looking for a spray-on coating for plastics (ABS) that will effectively shield low frequency (50 Hz) magnetic fields. Field strength reduction desired is about 0.5G.
Tam Chi Lam
technical services - Hong Kong
We are a skirting duct (electrical raceway) manufacturer and we are searching for information regarding the use of polymer (plastic) ducts which house adjacent cable runs of both 240 volt power and Cat5 data cable. There is not enough evidence to suggest UTP cannot be used with high speed data transmission. Perhaps a magnetic shielding coating will do the job? Does anyone else have results of any research?
Colin Wynn
- Brisbane, Australia
I'm looking for a coating that can be applied to aluminum. The more magnetic shielding the better!
Milton Sigelmann
- Seattle, Washington
