Letter 2088
Flash rust in wash tanks
We have a new finishing system installed in our facility.
The three-stage washer in this system has three mild steel wash
tanks. All three tanks arrived at our facility with flash rust inside
of them. After installing the washer, we have tried a couple of ways
of removing this rust.
One was to clean the tanks out and over flow them until the water
is clean. This attempt was moderately successful. The second attempt
was to add a small amount of muriatic acid to each tank and run the
washer tank spray pump of a short time to clean the rust. This worked
for a few days before the flash rust returned. This finishing line is
not in production yet so we would like to know the best way to clean
these tanks of rust. We want to have the water in these tanks as
clean as possible before we start regular production using this
system.
L. Rivers
- Columbia, South Carolina
Is it your tanks or your enclosure that is flash rusting? Out of
what material is the enclosure made? While I am still a baby in this
area, I believe that it is in the drying of the steel that most of
the flash rusting occurs. If you can keep it wet, it should not rust.
Easy to say, and hard to do when your not in production, or shut down
for the night! When we clean our mild steel parts, we rinse them with
a slightly (0.05% or so) acidic (phosphoric) rinse, this seems to
keep our parts from flashing, but may interfere with the chemistry
you plan to use during production. Hope that this helps more than it
confuses!!
Kelly Jones Draper
Flash rust is going to be present on the carbon steel tanks.
What is your chemical supplier saying about your problem?
The chemical supplier will play a key role, or should be playing a
key role in helping you understand the issue. If the chemical
supplier has told you not to worry about it, it is possibly good
advise.
I would urge you not to use muriatic acid to clean the tanks
again. If your do not have inhibitors in the acid solution the rust
can actually get worse.
When you add the chemicals to the baths using chemicals the rust
in these baths and the housing above will decrease. The tank and
housing of the rinse station will have reduced rust after the carry
over of chemicals occurs.
If you have verified, note i said verified, that the rust is going
to create a quality problem your only choice is to coat the sheet
metal.
Tyrone Caley
- Jefferson City, MO
While I am seeing a number of polypropylene washers and
phosphating lines these days, and some quite cool ones built of
stainless frames and heavy clear vinyl curtains, such equipment has
traditionally been mild steel and has proven satisfactory in years of
use, so I agree with Tyrone.
If it is alkaline-based washer chemistry, the tanks will not rust
in service. In fact a very simple, and somewhat effective temporary
rustproofing that some finishing shops employ on their
work-in-process is to simply dip the steel part in a hot alkaline
tank and let it dry on.
finishing.com
Brick, New Jersey
Ted's comment is particularly true if you use a heavily silicated
hot cleaner. The silicate forms a poor man's ceramic coating that is
very difficult to get off without blasting or use of fluorides.
A rust remover alkaline cleaner would be a lot better than HCl,
but a lot slower.
You might want to use
Naval Jelly [link is to product info at Amazon] which will give
the steel a poor man's phosphate coating.
I have treated the interior of a snowmobile gas tank with Naval
Jelly to remove heavy rust. The rust was converted to a black iron
residue that remains lightly adhered to the surface. I have since
filled the tank with water to figure out the next step.
What can I treat the reduced iron residue with to dissolve it into
a solution that I can discard? I can't have any foreign materials
floating in the gasoline mixture that will contaminate the
carburetor.
Michael Gleason
- Red Wing, MN, USA
