Aluminum Anodizing -- Alternate Cathode Materials
     Readers wanting a quick intro please see our Intro to Anodizing.
     In the anodizing of aluminum the parts we are anodizing comprise the anode; the cathodes (the required counter-electrode), were in the old days usually made of lead. These days, most anodizers favor aluminum cathodes, but the discussion continues. Read on ...
[editor appended this entry to this thread which addresses it]
Q. Does anyone have experience with sulfuric acid anodizing cathodes other than aluminum or lead?
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
June 27, 2024
A. Hi Chris. We added your inquiry to this thread where Phil Johnson mentioned the alternative of stainless steel cathodes. I've personally never seen them used in sulfuric acid anodizing (have seen them in chromic acid anodizing), I've seen nothing but lead or aluminum.
So far on this thread we've heard from 3 people who think stainless steel is not a good idea ... hopefully we'll hear from a user advocate for them so we can at least hear the hypothetical advantages of stainless steel  🙂
Q. Looking for peoples experience & opinions on which is better - using Aluminum or Stainless Steel cathodes in a anodizing tank.
David A. Kraft
- Long Island City, New York
"The Surface
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
pinner
A. David,
It depends on the anodizing processes you are using. For sulfuric acid anodizing, aluminum cathodes are better than SS cathodes from the economic point of view. For details, you may refer to some references:
• The Surface Treatment and Finishing of Aluminum and Its Alloys by S. Wernick, R. Pinner, P.G. Sheasby
  • p. 404; Plating and Surface Finishing, November 1981, p. 32-34;
    • Metal Finishing Guide Book and Dictionary Issue 98, p. 474;
      • and discussions in finishing.com 4th quarter 1997 or 1st quarter 1998 (topics 524, 554, 1177).
Ling
Ling Hao
- Grand Rapids, Michigan
A. Several years ago the job shop I worked in switched from lead to aluminum, following a paper on Al cathodes by Charlie Grubbs, then with Reynolds. Since we anodized most of our work by current density, rather than voltage, we quickly recognized that our loads were running about 1 to 1-1/2 volts lower than previously. This translates to close to at least a 10% power savings, and is probably even more, since there is less heat produced with consequent chiller power savings. Since then I've advocated Al cathodes. The difference between stainless and aluminum would probably not be as dramatic, but I still believe Al would save electricity, due to its higher conductivity.
If your loads are large enough, surface area-wise, that you need more cathode surface area than straight sheets can provide, Al is readily available in other shapes. The plant I worked in used 1-1/2" x 2" x 1" "U"" shaped extrusions. Drilling holes for connections is much easier in Al, as you probably know. We always used a conductive grease in joining Al cathodes or buss bars, to combat oxidation/corrosion.
Several of our large customers use stainless cathodes, but I am not that familiar with their long-term use. Maybe not everyone knows that weak sulfuric acid solutions will attack stainless steel, even 316, but not as much as Al, so stainless would probably last longer. It is not always practical, but for maximum cathode life it would be best to remove the cathodes from the anodize tank during prolonged down-times.
phil johnson
Phil Johnson
- Madison Heights, Michigan
A. The use of aluminum cathodes in preference to SS cathodes has stood the test of time. While Al has a conductivity of 55-60%, SS has about 7%. This translates into energy available for anodizing rather than producing heat.
Another factor to consider is the possible dissolution of Ni and Cr out of the SS cathodes.
Although sheet products are available that will work as cathodes, I have found that you have more flexibility with extrusions. These shapes will allow you to place the cathodes where they will do the most good.Many times a flat extrusion will suffice rather than trying to locate the more exotic shapes.
A 3:1 anode/cathode ratio has proven to be about the best in most general anodizing situations. I would STRONGLY suggest you use welded connections instead of bolts. Use alloy 5356 for welding and keep the welded joints out of the solution.
Charlie Grubbs
- Alpharetta, Georgia
Q. Other than electricity costs...can anyone tell me the advantages of using Al cathodes as opposed to 316L cathodes in a standard sulfuric hardcoat process? It would seem to me that the reduced energy costs would be replaced by higher cathode replacement costs? Drew.. I expect you'll be piping up on this one.....
Marc Green
Marc Green
anodizer - Boise, Idaho
A. Marc,
You knew this would be near and dear to my heart. The advantages of using a properly designed and alloy (6063-T6) aluminum cathodes bussing system is:
1 ) Better current distribution in the tank, therefore a more even oxide.
2) No added dissolved metal other than aluminum in the bath( lead, copper, nickel, iron). Very little aluminum from the cathodes get into the bath.
3) Because of better current distribution less burning.
4) More usable tank space.
5) Lighter and easier to handle.
6) Overall less cost.
7) Your Quality Control manager and I smile when you set it up!
drew nosti
Drew Nosti, CEF
Anodize USA - Ladson, South Carolina
Copper as Anodizing Cathodes
Q. Hi everyone,
Well, let me push the question further: Can anyone tell me the disadvantages of using Copper cathodes as opposed to any other material (Al, Pb, etc.) in a standard sulfuric hardcoat process? In fact, Cu is completely [ed. note: completely what?] in this type of acidic media.
Hocine Djelab
anodizing shop - Verdun, Quebec, CANADA
A. Copper is completely what? There is a missing word in your response. It strikes me that copper would be "soluble" in a sulfuric acid bath.
A. I'm not sure what the regs are in Canada, but the amount of dissolved copper in the anodize tank would be a waste treatment issue, here in the states. Copper in the aluminum is obviously detrimental to the anodizing process, so I wouldn't be surprised if the same were true if the copper were in the electrolyte.
Marc Green
Marc Green
A. Copper is a contaminant in anodizing and dissolves readily in 200 grams per liter of sulfuric acid with current. NOT an Option! In today's environment making finishing baths last longer, therefore producing more and better quality work is imperative. 6063-T6 aluminum bus bar and racks will save energy and rejects, and will not add copper contamination to the anodizing solutions.
drew nosti
Drew Nosti, CEF
! Dear Drew,
Now, as for copper being soluble in 200 grams per liter of sulfuric acid with current:
1) According to the diagram E (volts) vs. pH, Copper is completely stable and not at all soluble in acid even in solution with a negative pH. So, from a thermodynamics point of view Cu cannot oxidize unless its potential is brought to values greater than 0.34 Volts.
2) Since we are considering copper to be a cathode material in the sulfuric acid anodizing tank, its potential can never be positive (anodic).
3) Maybe I am wrong, but I don't subscribe to the idea that a cationic species could be considered as a harmful contaminant in any anodizing bath. In fact, the minute the current is applied these species are very much attracted by the cathode and would never approach the material being anodized (anode).
The only precaution to be taken is to make sure that the load would not stay long in the bath without current. This is a prerequisite. Failure to apply the current rapidly would lead to the following redox couple to take place at the surface of the aluminum:
Cu2+(from the solution) + 2 e => Cu (plated on aluminum) (E0 = 0.337 + 0.03 log (Cu2+) Volts)
Al (anodic material) => Al3+ (to the solution) + 3e (E0 = -1.55 - 0.06 pH Volts)
Metallic ions (cations) are very harmful contaminants in plating baths, where the material of interest is made cathodic.
Reference: M. Pourbaix, Atlas of Electrochemical Equilibria in Aqueous Solutions[this on Amazon affil links], Edt. NACE 1974
Kind regards,
Hocine Djellab [returning]
! Hi Ted, Marc
First sorry for the typo:
My last sentence should read as follows: "In fact, Cu is completely STABLE in this type of acidic media." For reference see: Atlas of Electrochemical Equilibria in Aqueous Solutions[this on Amazon affil links], By Marcel Pourbaix.
Ted,
Copper is not at all soluble in sulfuric acid bath and especially not when it's made cathodic, as it may be noted from the standard potential (E0) for the two following reactions:
Cu ---> Cu+ + 1e (E0 = 0.52 + 0.06log(Cu+)
Cu ---> Cu2+ + 2e (E0 = 0.337 + 0.03 log(Cu2+)
So in order to dissolve copper in baths with pH < 2, the potential (vs. a standard reference electrode) of the copper should be held at values greater than 0.34 Volts, which is never the case when it's made cathodic.
On the other hand, when the system is idle, copper is still stable as its potential is ZERO.
Marc,
You would not have any extra copper in your bath as a result of having your cathodes made of that metal. On the contrary, it is even a way of reducing your dissolved copper (from the treated alloys) by plating it on the copper cathodes as it is used in the Copper Electro-refining process.
Hocine Djellab
anodizing shop - Verdun, Quebec, Canada
thumbs up signHmmmmm....me thinks me is going to have to do a little research on this. I find it hard to believe that the copper won't dissolve in the standard H2SO4 anodizing bath. Stay tuned for my results. I did a little weight test over last weekend on some 6063 aluminum, and found that roughly, over the course of a year, that the 6063 will lose approx. 5% of its initial weight (the Al was just sitting idle, in our tank, with no current actually being applied). I'll duplicate the test with some copper and post the results. Hocine...are you currently using copper cathodes in your tank, or just considering the possibility?
Marc Green
Marc Green
thumbs up signDear Hocine,
I have always considered myself open minded so I am very interested in hearing more about the practical application of this new concept. I am sure as a member of the AESF Light Metal Committee we would love to receive a paper on the practical benefits of using copper cathodes in sulfuric, type II and hard coat type III anodizing baths. Would you do a paper on this subject or share with us some of the details about how long you have been using this technology. What type of production facility you have and the type of work you do. Also as I read your statement; how do you remove the copper cathodes in between loads? What % of copper is in the anodizing bath and does it effect the salt spray? Do you use air agitation ⇦ huh? ? I for one have not come across it before but would like to pursue some of the details.
drew nosti
Drew Nosti, CEF
A. Just for my 2 cents to this string we have been using aluminum cathodes in anodizing for years and they work well. But I remember years ago we used to electropolish SS in a strong phosphoric/sulfuric acid mixture and used copper as the cathode material and they worked just fine and this solution ran at 180 °F. So I would think copper would be a good choice for anodizing. Interesting concept.
Rick Richardson, MSF
Dayton, Ohio
!! Ok... here are my rather informal test results. I took a piece of copper..and lightly etched it in nitric acid to remove any loose burrs, rinsed well, and weighed. The weight was 36.514 grams. I left the piece in an ambient, non air agitated, 165 gr/liter sulfuric (tech grade) solution. After 5 days, I rinsed, dried, and re-weighed said piece, and came out with 36.493 grams. So...assuming I did the math correctly, the piece lost .00058% of its weight over the 5 day period, which, I believe translates into an approx. 4% weight loss over an entire year. Now, from what I understand through e-mails that have been sent to me...one would expect an increase in weight loss due to air agitation...but.. at the same time, I shouldn't see any loss while the current was actually being applied. So.. what does this all mean? Heck..I don't know!  🙂   I think I'll stick with Al just to be on the safe side!
Marc Green
Marc Green
Longevity of Titanium Cathodes
Q. Some time back, the aluminum sheets I was using as cathodes for anodizing completely dissolved into the bath. I was away from the system for about six months when it happened, and considering there was no current flowing, it hadn't occurred to me that I needed to remove the sheets. Does anyone know if this would also be an issue with titanium sheets? Can they be permanently immersed in a solution of 20-30% acid without dissolving over time? Also, the titanium I commonly see for sale is referred to as Grade 2 or Grade 5. Is this suitable for immersion in an anodizing bath? ⇦ Answer?
Jack Bryant
Hobbyist - Custom Electronics - Austin, Texas USA
April 13, 2015
Quick dissolution of aluminum cathodes
Q. I am using aluminium cathodes 6063 for sulfuric acid anodization. Lately we put new cathodes in and they dissolve rapidly, and I really wonder. The past one lasted five years,. I just found that there is a reaction while the tank is idle and the power contact is off, the acid concentration is 200 gm/l. What factor could cause the rapid dissolution of cathode in its idle state?
shaymaa .A
- cairo Egypt
August 6, 2020
A. If you are certain the free acid is only 200 g/L, then look for chlorides.
robert probert
probertbanner
Q. Please what do you mean by chlorides?
shaymaa .A [returning]
- cairo egypt
A. Hi Shaymaa. Table salt is NaCl, sodium chloride, and introduces Cl-, chloride ions, into the solution; hydrochloric acid is HCl, and introduces Cl-, chloride ions, into the solution. There may be Cl- in incoming water, or dragged into the process from elsewhere. Cl- is very corrosive and you should analyze or have the solution analyzed for chloride concentration.
A. Aluminium cathodes never dissolve unless anodizing bath runs or too much acid concentration in anodizing bath. We can't mention about aluminium cathodes lasting time because it depends on production density and volt/current value. If anodizing rectifier always works high capacity, lasting duration of cathodes will be shortened. I never heard as you say cathodes dissolve during idle time. How did you find this reaction as you claim? Also when did dissolve these cathodes? You say previous cathodes lasted inside five years so these ones less than five years? When? How long did take lasting these dissolved cathodes?
alaattin tuna
- TURKEY Sakarya
A. If you observed your cathode in red colour (copper deposition), then your cathode dissolution would be very fast. The copper content mainly come from low grade sulfuric acid or too much 2XXX series anodizing.
John Hu
Q. Dear alaattin tuna
I prepared the bath and there is reaction around cathode, like you said as if there is high concentration of acid, so I checked concentration and it's in normal range. I observed the cathode the past week and the thickness of the cathode changed -- I noticed it with my bare eyes. Also I hadn't mentioned the the cathode dissolved totally.
Dear John Hu,
Yes, the cathode is red colour but it's new cathodes and we are anodizing 7075 alloy and 7020 alloy; the past one was also red but it didn't dissolve that rapidly? shaymaa .A [returning]
- cairo egypt
Ed. note: Please see our on-line library article
"Why are my cathodes turning red?", and
• Forum topic 509/82 "Reddish-orange deposit on anodizing tank cathodes".
A. Hi Shaymaa. Are you sure the cathodes are from the same supplier and are the same alloy. What alloy are they?
Q. Dear Ted,
Yes the cathodes are from the same supplier; they are aluminium 6063, and we bought them at the same time and we used it for a little while and stored it and we just use it now.
- cairo egypt
A. What do you [mean] all "normal range"? 180 g/L without the presence of chloride will NOT dissolve your cathodes in less than 3 years, 200 g/L will slightly attack. 220 g/L will eat them up. If you consider 220 g/L as "normal" then you had better use stainless steel or lead.
robert probert
probertbanner
thumbs up sign Dear robert
I don't consider 220 gm/l normal range. I mainly work in in the range 160 to 180 gm/l -- I dilute the tank solution from 200 to 173 lately to avoid dissolving of the cathode rapidly.
- cairo egypt
A. If you newly make up your anodizing bath and place new cathode, you won't get to see your aluminium cathode in red except your sulfuric acid being used for making up contains too much copper. Additionally, when you make up the bath (if you use concentrated sulfuric acid to dilute) you should run the chiller to cool down the bath first then add in the sulfuric acid, otherwise the solution temperature will go up very high and this will contribute the fast dissolution of the cathode.
John hu
Q. Yes I noticed that the cathodes in red color ... but how come the sulfuric acid contains too much copper? And I also ask you to explain to me what is the relation between high copper content and quick dissolution of cathodes?
Thanks john!
- cairo egypt
August 14, 2020
? Can you share either bath's appearance or dissolved cathodes with us? You can send to Ted (finishingdotcompublic@gmail.com) and we can discuss better over pics.
Alaattin Tuna
- TURKEY Sakarya
A. Shaymaa:
if your anodizing bath contains Cu ion, the replacement reaction with aluminium cathode will occur automatically. Bear in mind that with the copper deposition, that mean there must be some aluminium dissolved. The problem is that this copper deposition coating is loose, not hard sticking to the cathode (easy peel off) when you air agitate the bath, when you doing anodizing (hydrogen release at the cathode to cause the copper coating to peel off). So once the old copper coating peels off, it exposes new aluminium surface that would continue to replace the copper ion to copper (red colour).
From the mechanism I describe here, we can conclude that as long as sulfuric acid grade low and contains high copper ion and because you need to top-up the bath (it means you continue to supply the copper ion), then the dissolving of the aluminium continues to happen.
John hu
